Hi all,
I’ve had this issue for quite a few LightBurn versions now and I’m always running the latest version.
After I finish a project, I often use the laser/device dropdown in the same LightBurn window to switch to another one of my lasers. Sometimes I’m using the same design on another machine, and other times I’m just moving on to a different job.
When I select another laser from the dropdown, LightBurn will very often just crash and completely close without any warning or error message.
Luckily, AutoSave usually recovers the work when I reopen LightBurn, but it’s getting pretty frustrating when I regularly switch between multiple lasers.
Because it has happened across several versions, I thought I’d finally mention it in case it isn’t a widely reported issue.
System details:
- Windows 11 Pro
- Version 25H2
- 64-bit
- Not the Windows N edition
- LightBurn kept up to date with the latest releases
Has anyone else experienced this when switching devices from the dropdown?
If there are any logs, crash reports or other information I can provide to help track it down, let me know.
