I am trying to configure my Comgrow USB Camera and when I attempt to save the camera in LB or Calibrate and Save my settings, LB crashes. I grabbed the error log -
Translated Report (Full Report Below)
Process: LightBurn [635]
Path: /Applications/LightBurn.app/Contents/MacOS/LightBurn
Identifier: com.LightBurnSoftware.LightBurn
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-02-18 17:10:22.1120 -0500
OS Version: macOS 13.2.1 (22D68)
Report Version: 12
Bridge OS Version: 7.2 (20P3045)
Anonymous UUID: FA415FB1-2284-ADDA-7181-E5F179E68541
Time Awake Since Boot: 5300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007e54cf4ba958
Exception Codes: 0x0000000000000001, 0x00007e54cf4ba958
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [635]
M Region Info: 0x7e54cf4ba958 is not in any region. Bytes after previous region: 15757208668505 Bytes before following region: 1514926266024
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
Stack 70000c704000-70000c786000 [ 520K] rw-/rwx SM=PRV thread 8
—> GAP OF 0xfb57b77a000 BYTES
MALLOC_LARGE 7fb587f00000-7fb589d7c000 [ 30.5M] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x7ff80bc19e1d objc_msgSend + 29
1 AVFCapture 0x7ff8272916fd -[AVCaptureSession_Tundra removeOutput:] + 170
2 libqavfcamera.dylib 0x13f91876d 0x13f906000 + 75629
3 libqavfcamera.dylib 0x13f9187ee 0x13f906000 + 75758
4 libqavfcamera.dylib 0x13f9122b4 0x13f906000 + 49844
5 libqavfcamera.dylib 0x13f9123ce 0x13f906000 + 50126
6 QtMultimedia 0x1099f32ae 0x1099e9000 + 41646
7 QtMultimedia 0x109a0c4d3 0x1099e9000 + 144595
8 QtMultimedia 0x109a0db7c QCamera::~QCamera() + 28
9 LightBurn 0x107e4f0d7 CameraCap::ReleaseCamera() + 55
10 LightBurn 0x10834dea4 MainWindow::closeEvent(QCloseEvent*) + 772
11 QtWidgets 0x10ae442ae QWidget::event(QEvent*) + 1070
12 QtWidgets 0x10af54545 QMainWindow::event(QEvent*) + 277
13 QtWidgets 0x10ae09d52 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
14 QtWidgets 0x10ae0b12d QApplication::notify(QObject*, QEvent*) + 573
15 QtCore 0x10a4f513f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
16 QtWidgets 0x10ae32e31 QWidgetPrivate::close_helper(QWidgetPrivate::CloseMode) + 193
17 LightBurn 0x10837e12d MainWindow::qt_metacall(QMetaObject::Call, int, void**) + 77
18 QtCore 0x10a5260b6 QMetaObject::activate(QObject*, int, int, void**) + 2230
19 QtWidgets 0x10ae00635 QAction::activate(QAction::ActionEvent) + 309
20 QtCore 0x10a51e554 QObject::event(QEvent*) + 788
21 QtWidgets 0x10ae004ea QAction::event(QEvent*) + 234
22 QtWidgets 0x10ae09d52 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
23 QtWidgets 0x10ae0b12d QApplication::notify(QObject*, QEvent*) + 573
24 QtCore 0x10a4f513f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
25 QtCore 0x10a4f6312 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 850
26 libqcocoa.dylib 0x109fb418e 0x109f89000 + 176526
27 libqcocoa.dylib 0x109fb4a41 0x109f89000 + 178753
28 CoreFoundation 0x7ff80c063b78 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
29 CoreFoundation 0x7ff80c063b27 __CFRunLoopDoSource0 + 157
30 CoreFoundation 0x7ff80c063961 __CFRunLoopDoSources0 + 308
31 CoreFoundation 0x7ff80c06257b __CFRunLoopRun + 929
32 CoreFoundation 0x7ff80c061b60 CFRunLoopRunSpecific + 560
33 HIToolbox 0x7ff8159af766 RunCurrentEventLoopInMode + 292
34 HIToolbox 0x7ff8159af396 ReceiveNextEventCommon + 199
35 HIToolbox 0x7ff8159af2b3 _BlockUntilNextEventMatchingListInModeWithFilter + 70
36 AppKit 0x7ff80f1b22f3 _DPSNextEvent + 909
37 AppKit 0x7ff80f1b1174 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1219
38 AppKit 0x7ff80f1a37b7 -[NSApplication run] + 586
39 libqcocoa.dylib 0x109fb383d 0x109f89000 + 174141
40 QtCore 0x10a4f0c92 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 418
41 QtCore 0x10a4f5852 QCoreApplication::exec() + 402
42 LightBurn 0x10831b99c main_global(int, char**) + 3196
43 dyld 0x7ff80bc55310 start + 2432
Thread 1:
0 libsystem_kernel.dylib 0x7ff80bf4bfea __semwait_signal + 10
1 libsystem_c.dylib 0x7ff80be60a9a nanosleep + 196
2 libsystem_c.dylib 0x7ff80be6b98a sleep + 41
3 LightBurn 0x108394be1 0x107d70000 + 6441953
4 libsystem_pthread.dylib 0x7ff80bf88259 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff80bf83c7b thread_start + 15
Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff80bf495c2 mach_msg2_trap + 10
1 libsystem_kernel.dylib 0x7ff80bf57604 mach_msg2_internal + 82
2 libsystem_kernel.dylib 0x7ff80bf50635 mach_msg_overwrite + 723
3 libsystem_kernel.dylib 0x7ff80bf498a8 mach_msg + 19
4 CoreFoundation 0x7ff80c063cbe __CFRunLoopServiceMachPort + 145
5 CoreFoundation 0x7ff80c06272a __CFRunLoopRun + 1360
6 CoreFoundation 0x7ff80c061b60 CFRunLoopRunSpecific + 560
7 AppKit 0x7ff80f313179 _NSEventThread + 132
8 libsystem_pthread.dylib 0x7ff80bf88259 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff80bf83c7b thread_start + 15
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff80bf522da __select + 10
1 CoreFoundation 0x7ff80c08b49a __CFSocketManager + 643
2 libsystem_pthread.dylib 0x7ff80bf88259 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff80bf83c7b thread_start + 15
Thread 4:: caulk.messenger.shared:17
0 libsystem_kernel.dylib 0x7ff80bf4953e semaphore_wait_trap + 10
1 caulk 0x7ff8156fb8f8 caulk::mach::semaphore::wait_or_error() + 16
2 caulk 0x7ff8156e1664 caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x7ff8156e1328 void* caulk::thread_proxy<std::__1::tuple<caulk:
:attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 41
Thread 5:: QThread
0 libsystem_kernel.dylib 0x7ff80bf502d6 poll + 10
1 QtCore 0x10a549c40 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 112
2 QtSerialPort 0x10992504c 0x10991d000 + 32844
3 QtSerialPort 0x109924ef1 0x10991d000 + 32497
4 LightBurn 0x107f97030 SerialThread::ServiceReads() + 64
5 LightBurn 0x107f95548 SerialThread::run() + 1608
6 QtCore 0x10a3460a7 0x10a318000 + 188583
7 libsystem_pthread.dylib 0x7ff80bf88259 _pthread_start + 125
8 libsystem_pthread.dylib 0x7ff80bf83c7b thread_start + 15
Thread 6:: QThread
2 QtCore 0x10a54963b 0x10a318000 + 2299451
3 LightBurn 0x107ff1ebc Protocol_GCode_Thread::GetCommandResult() + 2972
4 LightBurn 0x107ff0896 Protocol_GCode_Thread::run() + 1126
5 QtCore 0x10a3460a7 0x10a318000 + 188583
6 libsystem_pthread.dylib 0x7ff80bf88259 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff80bf83c7b thread_start + 15
Thread 7:
0 libsystem_pthread.dylib 0x7ff80bf83c58 start_wqthread + 0
Thread 8:: Dispatch queue: com.apple.root.user-interactive-qos
7 Foundation 0x7ff80cebe02a -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216
8 AppKit 0x7ff80f5cd19a -[NSAnimation _runBlocking] + 446
9 AppKit 0x7ff80f5cd4fd __30-[NSAnimation _runInNewThread]_block_invoke + 97
10 libdispatch.dylib 0x7ff80be077fb _dispatch_call_block_and_release + 12
11 libdispatch.dylib 0x7ff80be08a44 _dispatch_client_callout + 8
12 libdispatch.dylib 0x7ff80be187f6 _dispatch_root_queue_drain + 683
13 libdispatch.dylib 0x7ff80be18e4d _dispatch_worker_thread2 + 160
14 libsystem_pthread.dylib 0x7ff80bf84c9d _pthread_wqthread + 256
15 libsystem_pthread.dylib 0x7ff80bf83c67 start_wqthread + 15
Thread 9:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x7ff80bf4ad42 __ulock_wait + 10
1 libdispatch.dylib 0x7ff80be09233 _dlock_wait + 45
2 libdispatch.dylib 0x7ff80be094cf _dispatch_group_wait_slow + 43
3 CoreMediaIO 0x7ff81acf8033 -[CMIOExtensionProviderHostContext completeTransaction] + 79
4 CoreMediaIO 0x7ff81ace4065 CMIO::DAL::CMIOExtension::PlugIn::SetPropertyData(CMIOObjectPropertyAddress const&, unsigned int, void const*, unsigned int, void const*) + 1769
5 CoreMediaIO 0x7ff81acf8961 CMIOObjectSetPropertyData + 314
6 AVFCapture 0x7ff8272c0bb5 __65+[AVCaptureDALDevice setOnAllCMIOPlugInsTheUInt32Property:value:]_block_invoke + 324
7 libdispatch.dylib 0x7ff80be077fb _dispatch_call_block_and_release + 12
8 libdispatch.dylib 0x7ff80be08a44 _dispatch_client_callout + 8
9 libdispatch.dylib 0x7ff80be0b16e _dispatch_queue_override_invoke + 811
10 libdispatch.dylib 0x7ff80be186a2 _dispatch_root_queue_drain + 343
11 libdispatch.dylib 0x7ff80be18e4d _dispatch_worker_thread2 + 160
12 libsystem_pthread.dylib 0x7ff80bf84c9d _pthread_wqthread + 256
13 libsystem_pthread.dylib 0x7ff80bf83c67 start_wqthread + 15
Thread 10:
Thread 11:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0xda331841db010005 rbx: 0x00006000010aa940 rcx: 0x00007ff84d59ed20 rdx: 0x00006000010aa2a0
rdi: 0x00006000010aa940 rsi: 0x00007ff82bfe7d06 rbp: 0x00007ff7b818cf70 rsp: 0x00007ff7b818ce58
r8: 0x0000000000000155 r9: 0x0000000000000154 r10: 0x00007e54cf4ba940 r11: 0x00007ff82bfe7d06
r12: 0x00000001094899f0 r13: 0x00000019000000ba r14: 0x00006000010aa2a0 r15: 0x00007ff80bc19e00
rip: 0x00007ff80bc19e1d rfl: 0x0000000000010202 cr2: 0x00007e54cf4ba958
Logical CPU: 4
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
01 76 17 49 83 c3 10 49-3b 33 75 f1 49 8b 43 08 .v.I…I;3u.I.C.
48 83 f8 00 74 03 4c 31-d0 c3 eb 00 31 c0 c3 66 H…t.L1…1…f
66 66 66 66 66 2e 0f 1f-84 00 00 00 00 00 66 66 fffff…ff
66 66 66 66 2e 0f 1f 84-00 00 00 00 00 66 0f 1f ffff…f…
44 00 00 48 85 ff 2e 74-72 40 f6 c7 01 2e 75 76 D…H…tr@…uv
49 ba f8 ff ff ff ff 7f-00 00 4c 23 17 49 89 f3 I…L#.I…
[45]23 5a 18 49 c1 e3 04-4d 03 5a 10 49 3b 33 75 E#Z.I…M.Z.I;3u <==
0a 4d 8b 5b 08 4d 31 d3-41 ff e3 49 83 3b 01 76 .M.[.M1.A…I.;.v
13 49 83 c3 10 49 3b 33-75 f1 4d 8b 5b 08 4d 31 .I…I;3u.M.[.M1
d3 41 ff e3 72 70 4d 8b-5b 08 eb 0a 49 83 3b 01 .A…rpM.[…I.;.
76 13 49 83 c3 10 49 3b-33 75 f1 4d 8b 5b 08 4d v.I…I;3u.M.[.M
31 d3 41 ff e3 eb 4f 0f-1f 40 00 31 c0 31 d2 0f 1.A…O…@.1.1…
Binary Images:
0x7ff80bc13000 - 0x7ff80bc4efd8 libobjc.A.dylib () /usr/lib/libobjc.A.dylib
0x7ff82726c000 - 0x7ff8273eaff1 com.apple.AVFCapture (1.0) <459fa56d-76d4-3fae-a90b-ff65e0a56513> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
0x13f906000 - 0x13f933fff libqavfcamera.dylib () /Applications/LightBurn.app/Contents/PlugIns/mediaservice/libqavfcamera.dylib
0x1099e9000 - 0x109a5efff org.qt-project.QtMultimedia (5.11) /Applications/LightBurn.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
0x107d70000 - 0x1093dbfff com.LightBurnSoftware.LightBurn () <01c3102e-8e74-3de0-89eb-5284ecc6a2d4> /Applications/LightBurn.app/Contents/MacOS/LightBurn
0x10adfa000 - 0x10b22dfff org.qt-project.QtWidgets (5.11) /Applications/LightBurn.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x10a318000 - 0x10a803fff org.qt-project.QtCore (5.11) <02cecf89-9d8b-3cad-a3d9-0618e34152bf> /Applications/LightBurn.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x109f89000 - 0x10a0dcfff libqcocoa.dylib () /Applications/LightBurn.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x7ff80bfe4000 - 0x7ff80c47dfef com.apple.CoreFoundation (6.9) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff815980000 - 0x7ff815c77ffd com.apple.HIToolbox (2.1.1) <7bf47984-29cb-319e-a6da-0884d158f96a> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff80f174000 - 0x7ff81017cff2 com.apple.AppKit (6.9) <540cedfd-5a35-3f35-8953-dcb7c4834eb5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff80bc4f000 - 0x7ff80bce3caf dyld () /usr/lib/dyld
0x7ff80bf48000 - 0x7ff80bf81ff7 libsystem_kernel.dylib () <87ff381c-4d30-3087-bab7-a5a53d232c00> /usr/lib/system/libsystem_kernel.dylib
0x7ff80be50000 - 0x7ff80bed8fff libsystem_c.dylib () <1aec5d1a-6e43-30f9-a9f2-11eb85d3e70c> /usr/lib/system/libsystem_c.dylib
0x7ff80bf82000 - 0x7ff80bf8dff7 libsystem_pthread.dylib () <3bd433d4-15bd-3add-a612-95e4d3b20719> /usr/lib/system/libsystem_pthread.dylib
0x7ff8156df000 - 0x7ff815704fff com.apple.audio.caulk (1.0) /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x10991d000 - 0x109929fff org.qt-project.QtSerialPort (5.11) <49d86de6-2a03-358e-842d-3bc86dd7f093> /Applications/LightBurn.app/Contents/Frameworks/QtSerialPort.framework/Versions/5/QtSerialPort
0x7ff80ce5f000 - 0x7ff80d870ff6 com.apple.Foundation (6.9) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff80be06000 - 0x7ff80be4cff3 libdispatch.dylib () /usr/lib/system/libdispatch.dylib
0x7ff81ac9a000 - 0x7ff81ad8dff5 com.apple.CoreMediaIO (1000.0) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x0 - 0xffffffffffffffff ??? () <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Translated Report.txt (46.6 KB)
