Lightburn Creality Rotary Chuck
Hi
I have recently bought the rotary chuck to go with my laser - however when i turn rotary mode on in lightburn it doesnt seem to engage or move it. The laser still treats the work area as a flat bed rather than a rotational item?
Any Help would be greatly appreciated
Many Thanks
Does the Yaxis still move?
We’re going to need a bit more information here. How is it plugged in? Have you turned on rotary mode? Which axis did you select? Did you configure the rotary settings?
Hi Both
Thank you for your reply - in my infinite wisdom i didnt realise that there was a further check i needed to do with the Axis . . . its currently set at Y Axis but i will need to have a further check later today once i get the chance and check how the other axis selections interact
so to resolve this - i hadnt selected Z Axis in the options my bad
Now just to set up the mm per rotation etc to make sure all is good
Thanks Again
