I have an OMTech 60w with Rui
da controller. Every file I cut directly from lightburn cuts mirrored. If I send the file to the machine and then cut it cuts normal
What setting in lightburn should I be checking to correct this problem.
There is also a ‘screen origin’ on the Ruida to indicate where it’s oriented on the controllers screen.
Let me add here in case it’s referenced but home position and origin position are not always going to be the same. Although I think this tends to be the case with Ruida setups.
…also applies to my clone KT332N ![]()
