Lightburn doesn’t engrave lower 1/16 of an inch of some letters and graphics
I experienced a strange issue that I want to report.
Date – Dec/6/2023
LightBurn 1.4.03
Laser - Atomstack-X7-Pro
OS – Win11 Pro with all updates
Computer – Dell XPS 9500 with 40Gig RAM with all updates
The lower 1/16 of an inch of some letters and graphics was not engraving. And it was just some of the letters and graphics in the same design.
Attached are some pics showing what happened.
See pic showing #5, the bottom of the 5 did not get engraved. Also the small S got clipped. But the arrow graphic and the other text is fine.
See pic showing #3 and the sideways teardrop. The bottom of the 3 and the teardrop did not get engraved. The corner of the R got clipped as well. But none of the other text or graphics.
I’m guilty of playing with the settings to improve the engraving and speed it up if possible.
I finally found which setting I changed that started causing the issue.
In the “cut settings editor” I changed from “fill all shapes at once” to “fill groups together”. Using this setting reduced the engrave time by about 30 minutes.
It doesn’t make any sense to me why this change would cause that issue.
When I changed back to “fill all shapes at once" the problem disappeared.
Jim
