NigelH
(Nigel Hanly)
March 6, 2023, 6:40pm
1
I realise the following has been asked numerous times but the solutions given don’t seem to be working for me. Rotary is disabled, settings are correct, have removed laser and reconnected. Atomstack S20 pro is the laser in question, everything was perfect until this.
; LightBurn 1.3.01
; GRBL device profile, absolute coords
; Bounds: X143.67 Y51.75 to X172.41 Y80.25
G00 G17 G40 G21 G54
G90
M4
; Image @ 3000 mm/min, 20% power
M8
G0 X154.87Y51.754
; Layer C00
G91
G1 X1.25F3000S0
G1 X0.501S200
G1 X1.25S0
G1 X0.167Y0.084S0
G1 X-1.25S0
G1 X-0.584S200
G1 X-1.25S0
G1 Y0.083S0
G1 X1.25S0
G1 X0.167S200
G1 X0.334S0
G1 X0.167S200
G1 X1.504S0
G1 X0.585S200
G1 X1.25S0
G1 X0.167Y0.084S0
G1 X-1.25S0
G1 X-0.752S200
G1 X-1.42S0
G1 X-0.168S200
Will_vl
(Will Vander Linden)
March 6, 2023, 6:49pm
2
Can you describe the problem, or more accurately, what you were expecting?
NigelH
(Nigel Hanly)
March 6, 2023, 6:53pm
3
The following is showing in the console, it will frame the job but will not start the job
Starting stream
Layer Labels
[MSG:M4 requires laser mode or a reversable spindle]
error:20
Unsupported or invalid g-code command found in block.
On or near line 2:
Job halted
Stream completed in 0:00
ok
ok
Will_vl
March 6, 2023, 7:00pm
4
Can you please report the value of $32 ?
NigelH
(Nigel Hanly)
March 6, 2023, 7:05pm
5
$32 = 0
Sorry im a noob, have now set to 1 and is working.
Thank you so much for the help, dont know how it happened
Will_vl
March 6, 2023, 7:13pm
6
No need to apologize. Everyone starts out ‘new’.
Glad your issue is resolved
silvan
(silvana parisi)
March 29, 2023, 4:03pm
7
error:20
Comando g-code non supportato o non valido trovato nel blocco.
Sulla linea o vicino alla linea 2:
Job halted
error:20
On or near line 2:
Job halted
system
(system)
Closed
April 28, 2023, 4:04pm
8
