Lightburn error 22 what's the fix?
What’s the fix to error 22 I got it after updating lightburn I have a ortur laser master 3 so found the recommended settings on here actually and set them up it started running then it would ether cut or engrave not both so I searched for a fix and finally found by trial and error that it would only do both after I frame
Congratulations and welcome to the forum.
Perhaps you´re machine is getting some electrical noise.
Try lowering your machine speed.
Check if your device is still set as plain GRBL only.
Do you get some LEDs blinking?
Can you post your .lbrn2 project file where this happens?
