When ever I etch laser travel lines are showing
Most common cause of this is that laser mode is not enabled in GRBL settings.
2 options:
- Edit->Machine Settings->set $32=1
- Issue this command in Console:
$32=1
I am unable to figure out how to do this
Do you see a Console window anywhere in the application? If not, go to Windows->Console to enable the window.
From there, enter this into the Input field and then copy/paste the output of that command into a reply here:
