I’ve been dealing with a bug for a while now where every time I open lightburn and try to send a file to my laser it always fails the first time but then works every time after. the error message I get is as follows.
file transfer failed
There was a problem sending data to the laser. The machine may be busy or paused.
I’m running a ruida controller with firmware version RDLC-V1.01.01 and am connected over USB. I have several files on my computer that I cut often so my workflow is to click on the desired .lbrn2 file from the file browser to launch lightburn and depending on the file either I either hit send once lightburn opens or I use the print and cut feature to align the job and then hit send. The first send always fails and gives me that error message but once I hit send again it always works.
I don’t think this plays a role but I figured it was worth mentioning, the files I cut often also always pop up the “file exists already - overwrite it?” prompt because I’ve sent them to the controller before.
Does anyone have an idea if I’m doing something wrong, have been dealing with a similar problem, or if the software team is aware of the bug?
