Lightburn frame alignment function with Atomstack X70
I am using a Atom Stack X70 with lighburn and when I use the frame function the atomstack light id in the corner of the laser body and is not directly in line with the lase head. Is there any way of adjusting to anine in lightburn or Atomstack
This ist only the case if you set a red pointer offset in device settings. Disable that one.
