Lightburn freezes after each job, I’m able to work on and send a job to the laser. When it is done, I try to send the same job to the laser and it just freezes. I need to restart lightburn and the laser in order to get things to work again. I’m running the latest version of lightburn, with windows 11.
Lightburn doesn’t ‘freeze’ until you click send the second time?
Lightburn should not ‘hang’, give it time to finish what it’s doing.
If it continues, you should send it and all files to the support@lightburnsoftware.com and let them examine it.
If it’s the same job, the code is on the Ruida when you sent it, just press ‘start’ on the machine.
