Lightburn galvo co2 - busy / disconnected laser cycling
Tried light burn for galvo today.
my c02 laser was detected & imported my ezcad settings.
however in the laser status panel, it just sits cycling between busy & disconnected every couple of seconds.
i have gone through the setup 3 times now & same result. I switched back to ezcad & did need to power off the laser to get it too load , but all working normally.
many thanks
Do you have the device selected in the laser window? When I was setting mine up after importing the settings it defaulted to the other laser.
Same issue here after having issues on a machine with a Fiber. Stood up a new machine and have the exact same behavior as the OP.
