I’ve seen many people using these on utube. Followed directions when downloading Light burn for galvo, everything else seems to work fine. Just no 3d slice and Q factor. Thank you in advance. Herb
You are showing your galvo as a Commarker B4, as I understand it, if it is not the Mopa version then the Q-Pulse option will be greyed out.
You should however still see the 3D sliced option in the cut settings for your image.
Hi David Thank You for the help., I really appreciate it.
Best Regards
Herb
