Is anyone able to tell me if any of the lighburn profiles output a spindle command for each G1 move when outputting a cut/line layer?
I have used a grbl controller previously, but have recently switched to UCCNC. I am able to get excellent results with filling using the grbl-m3 profile outputs and substituting the S commands with M10 commands as it outputs a spindle command for each move. But this is proving more complicated for cut moves other than manually adding them to each line.
I have seen a number of other posts around using lightburn with UCCNC and the problems with using a laser with this type controller, but UCCNC have implemented work around methods that seem to work well with filling just having less reliable success with lines.
Many thanks
