Hey there. I recently built a new plotter with a FYSETC controller that currently runs ESP3D for Marlin. The board has fixed IP on my home wifi and I have successfully connected to the web interface (over wifi) and fired commands/uploaded GCode manually.
I’d like to send GCode directly from Lightburn to the controller but I’m having connection issues with the IP that works for the web client. Can I still do this with the web UI in place? - I’d like to keep it for debug etc. if possible. If not, what config changes do i need to make?
Thanks!
The Marlin device profile is not configured to work with anything but USB. Additionally, the only WiFi connections supported for g-code devices is serial over telnet. Does your machine support this?
If not, then a direct connection for LightBurn is not going to work even if the Marlin profile supported IP connections.
Thanks for the reply - I’ve since switched to FluidNC which seems to work well - however I concluded that wifi is still out of each since I’m on a Mac and cannot setup a virtual com port to act as a serial connection for Lightburn - which is kind of what I was trying to express previously (unsuccessfully). I’ll make do with manually dropping the gcode over the web UI.
I haven’t tried it but it appears FluidNC supports Telnet connections. You may be able to connect directly from LightBurn in that case.
FluidNC works well over wifi using the standard GRBL device type and Ethernet/TCP as the connection. Just enter in the IP of your FluidNC device and it should connect up ok.
You may need to change the “transfer mode” in device settings. I think buffered is what I used that worked the best. It has been about a year since I tried it out.
