Hello,
my first post and I have following problem
Light burn generates in the g code a short additional cut line at the start of rectangle . Sometimes straight or with angle
It s cutting a line of 3-4 mm long always at start of a new contour . -
See attached fotos (if I can manage it )
It s definitively in the g code , and it s not from the import of DXF ( double lines) - i check it with my other setup milling router software , and there no such problem
I use light burn 1.4 - and I cut only 1 pass
I can imagine that this a setting somewhere in LB but I was not able to localize it ![]()
Any advice will be much appreciated
Thank you
Willy
