Lightburn import from coreldraw
In lightburn. I can’t setup say a bunch of names and a cut outline in corel and export as svg having the fonts in say black and cut line in red and bring into lightburn and do fills on the font names and a line for cutting for the red colored outline like I can in xtool xcs??
Thanks
Works fine exactly as you say.
The colors should match the LightBurn palette for best results, so use the Corel file from the doc:
Turn on the Allow Importing to Tool Layers switch if you have (properly colored) construction lines or notes that should go onto those layers.
If you need the Corel colour palette that matches the LightBurn layers, I can give you a copy of the palette I made. I use it when I’m designing for Lightburn because it transfers directly into the layers I want. You’ll still need to specify if the layer is a fill or cut in Lightburn. Corel saves custom palettes as a HTML file so all that is needed is to add it to the Corel Palettes folder located in the “Documents” folder in Windows. No idea where it’s located if you have a Mac.
