Started a print and cut session. Jogged to first reference position and selected. Moved to second reference point. Device froze. No movement. Powered off. Repositioned head manually. Tried to initiate print and cut. Nothing!!
Many attempts to activate device. Re-loaded firmware. Reloaded latest software. NOTHING
When I connect to com port head making faint noises as if trying to move???
Attached is (extremely} long Console print out. [I cut it short as printout exceeded allowable character length!]
Waiting for connection…
Guru Meditation Error: Core 1 panic’ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40087cfc: 6a605959 20668010 09694949
Core 1 register dump:
PC : 0x40087d00 PS : 0x00050031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0
A2 : 0x00000002 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8
A6 : 0x00000000 A7 : 0x10587374 A8 : 0x061e4500 A9 : 0x3ff5f000
A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffb1b90
A14 : 0x00000000 A15 : 0xf4516150 SAR : 0x00000020 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Core 1 was running in ISR context:
EPC1 : 0x40087d00 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72
ELF file SHA256: 0000000000000000
Backtrace: 0x40087d00:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4015f691:0x3ffb1c90 0x4015e711:0x3ffb1cf0 0x4015ec4d:0x3ffb1d30 0x4012e3c6:0x3ffb1d50 0x4012e52e:0x3ffb1d90 0x4012e555:0x3ffb1db0 0x400eedff:0x3ffb1dd0 0x400eef17:0x3ffb1df0 0x40154cf9:0x3ffb1e10 0x400dde79:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0
Rebooting…
f~f~
Memory dump at 0x40087cd8: 580c8920 e2192102 28200588
PC : 0x40087cdf PS : 0x00050031 A0 : 0x3ffc7cfc A1 : 0x3ffc02a0
A2 : 0x00000001 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8
A6 : 0x00000000 A7 : 0x13000654 A8 : 0x3ff60000 A9 : 0x3ff5f000
A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x00000008
A14 : 0x3ffc747c A15 : 0xfffffff7 SAR : 0x00000018 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
EPC1 : 0x40087cdf EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72
Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4008ed75:0x3ffba1f0 0x4008b6a3:0x3ffba210 0x400920c2:0x3ffba230
Rebooting…
f~~f~x
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3ff60000 A9 : 0x3ff5f000
A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8
A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x00000000
Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60
Rebooting…
f~f~
Guru Meditation Error: Core 1 panic’ed (LoadProhibited). Exception was unhandled.
PC : 0x400833ab PS : 0x00060031 A0 : 0x80086f5c A1 : 0x3ffc0260
A2 : 0x3ffb8b2c A3 : 0x3ffb8c2c A4 : 0x00000020 A5 : 0x80000020
A6 : 0x00000008 A7 : 0x00000001 A8 : 0x80086e46 A9 : 0x3ffc0240
A10 : 0x3ffafeb8 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x3ffc73b0
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000012 EXCCAUSE: 0x0000001c
EXCVADDR: 0x80086f5c LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
EPC1 : 0x400833ab EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72
Backtrace: 0x400833ab:0x3ffc0260 0x40086f59:0x3ffc0280 0x40087c8d:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60
Rebooting…
f~~xx����xx~怘�怘�~fffffff
f Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087c30: 0020c028 c0296932 68220020 Core 1 register dump: PC : 0x40087c37 PS : 0x00050031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000000 A3 : 0x00000001 A4 : 0x0000006c A5 : 0x400947a8 A6 : 0x3ffb1cc4 A7 : 0x3ffb1c8c A8 : 0x3ff60000 A9 : 0x3ff5f000 A10 : 0x00000008 A11 : 0x3ffb1cdc A12 : 0x0000003f A13 : 0x3ffb1c10 A14 : 0x3ffb1cc4 A15 : 0x2fa76cbe SAR : 0x00000012 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x40087c37 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087c37:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4014bf2b:0x3ffb1c80 0x4014b4a9:0x3ffb1cb0 0x4014b4cd:0x3ffb1d40 0x40146253:0x3ffb1d60 0x40135d4b:0x3ffb1d80 0x4013305f:0x3ffb1da0 0x40162f05:0x3ffb1dc0 0x400dd93d:0x3ffb1e00 0x400dde08:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ ok:start Stack smashing protect failure! abort() was called at PC 0x401578ab on core 1 ELF file SHA256: 0000000000000000 Backtrace: 0x400901d8:0x3ffb1ec0 0x40090455:0x3ffb1ee0 0x401578ab:0x3ffb1f00 0x40087201:0x3ffb1f20 0x400d4aa3:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cfc: 6a605959 20668010 09694949 Core 1 register dump: PC : 0x40087d00 PS : 0x00050031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000002 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x3f40c770 A7 : 0x01e40d51 A8 : 0x00000000 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffb1c60 A14 : 0x3ffb1cc4 A15 : 0x3ffb1c8c SAR : 0x00000014 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x40087d00 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087d00:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x40135d51:0x3ffb1d20 0x4013792a:0x3ffb1d40 0x40137a60:0x3ffb1d60 0x40135d4e:0x3ffb1d80 0x4013305f:0x3ffb1da0 0x40162f05:0x3ffb1dc0 0x400dd93d:0x3ffb1e00 0x400dde08:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ Memory dump at 0x40087938: 309e90fe c01099c0 0a990020 Core 1 register dump: PC : 0x4008793f PS : 0x00060730 A0 : 0x800d3938 A1 : 0x3ffb1ef0 A2 : 0x00000022 A3 : 0x00000001 A4 : 0x00000001 A5 : 0x00000001 A6 : 0x00060520 A7 : 0x00000000 A8 : 0x3f4033b4 A9 : 0x00000000 A10 : 0x3ff48480 A11 : 0x00000014 A12 : 0x00000000 A13 : 0x3ffb4000 A14 : 0xffffffff A15 : 0x00000000 SAR : 0x00000020 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000 Backtrace: 0x4008793f:0x3ffb1ef0 0x400d3935:0x3ffb1f10 0x400d4992:0x3ffb1f30 0x400817bf:0x3ffb1f60 0x400d4a91:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~~ ok:start time out 1s time out 1s time out 1s Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087b50: e0e37f81 0a2d0008 0000f01d Core 0 register dump: PC : 0x40087b56 PS : 0x00060430 A0 : 0x80081aa3 A1 : 0x3ffe2380 A2 : 0x3ffb81cc A3 : 0x3ffb81cc A4 : 0x00000020 A5 : 0x80000020 A6 : 0x00000003 A7 : 0x00060223 A8 : 0x80087b56 A9 : 0x3ffe2360 A10 : 0x0000031d A11 : 0x00000000 A12 : 0x0000031d A13 : 0x00001040 A14 : 0x00000000 A15 : 0x3ffe0480 SAR : 0x0000000a EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000 Backtrace: 0x40087b56:0x3ffe2380 0x40081aa0:0x3ffe23a0 0x400920c2:0x3ffe23e0 Rebooting... f~f~ Memory dump at 0x40087980: 91fa1c18 1200e3e8 a1880040 Core 0 register dump: PC : 0x40087986 PS : 0x00060830 A0 : 0x800da768 A1 : 0x3ffb3ec0 A2 : 0x00000003 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001 A6 : 0x00060820 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x3ff44000 A10 : 0x0000001f A11 : 0x00000084 A12 : 0x00060820 A13 : 0x00000001 A14 : 0x00060823 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000 Backtrace: 0x40087986:0x3ffb3ec0 0x400da765:0x3ffb3ee0 0x400dac65:0x3ffb3f00 0x400da409:0x3ffb3f40 0x400d5daa:0x3ffb3f80 0x40081a4d:0x3ffb3fc0 0x400920c2:0x3ffb3fe0 Rebooting... f~f~ Memory dump at 0x40087980: 91fa1c18 1200e3e8 a1880040 Core 0 register dump: PC : 0x40087986 PS : 0x00060830 A0 : 0x800da768 A1 : 0x3ffb3ec0 A2 : 0x00000003 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001 A6 : 0x00060820 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x3ff44000 A10 : 0x0000001f A11 : 0x00000084 A12 : 0x00060820 A13 : 0x00000001 A14 : 0x00060823 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000 Backtrace: 0x40087986:0x3ffb3ec0 0x400da765:0x3ffb3ee0 0x400dac65:0x3ffb3f00 0x400da409:0x3ffb3f40 0x400d5daa:0x3ffb3f80 0x40081a4d:0x3ffb3fc0 0x400920c2:0x3ffb3fe0 Rebooting... f~f~ f~f~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cfc: 6a605959 20668010 09694949 Core 1 register dump: PC : 0x40087d00 PS : 0x00050031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000003 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x00000000 A8 : 0xe00a1400 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8 A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000016 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x40087d00 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087d00:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~f~ Memory dump at 0x40087980: 91fa1c18 1200e3e8 a1880040 Core 0 register dump: PC : 0x40087986 PS : 0x00060830 A0 : 0x800da768 A1 : 0x3ffb3ec0 A2 : 0x00000003 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001 A6 : 0x00060820 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x3ff44000 A10 : 0x0000001f A11 : 0x00000084 A12 : 0x00060820 A13 : 0x00000001 A14 : 0x00060823 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000 Backtrace: 0x40087986:0x3ffb3ec0 0x400da765:0x3ffb3ee0 0x400dac65:0x3ffb3f00 0x400da409:0x3ffb3f40 0x400d5daa:0x3ffb3f80 0x40081a4d:0x3ffb3fc0 0x400920c2:0x3ffb3fe0 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 1 register dump: PC : 0x00ffe746 PS : 0x00060031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000000 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x76e61073 A8 : 0x80087c90 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffb1b90 A14 : 0x00000000 A15 : 0xf4516150 SAR : 0x0000001e EXCCAUSE: 0x00000014 EXCVADDR: 0x00ffe744 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x00ffe746 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x00ffe746:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4015f673:0x3ffb1c90 0x4015e711:0x3ffb1cf0 0x4015ec4d:0x3ffb1d30 0x4012e3c6:0x3ffb1d50 0x4012e52e:0x3ffb1d90 0x4012e555:0x3ffb1db0 0x400eedff:0x3ffb1dd0 0x400eef17:0x3ffb1df0 0x40154cf9:0x3ffb1e10 0x400dde79:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cd8: 580c8920 e2192102 28200588 Core 1 register dump: PC : 0x40087cdf PS : 0x00050031 A0 : 0x3ffc7cfc A1 : 0x3ffc02a0 A2 : 0x00000002 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3ff60000 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8 A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000016 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x40087cdf EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Core 1 register dump: PC : 0x400833ab PS : 0x00060031 A0 : 0x80086f5c A1 : 0x3ffc0260 A2 : 0x3ffb8b2c A3 : 0x3ffb8c2c A4 : 0x00000020 A5 : 0x80000020 A6 : 0x00000008 A7 : 0x00000001 A8 : 0x80086e46 A9 : 0x3ffc0240 A10 : 0x3ffafeb8 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x3ffc73b0 A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000012 EXCCAUSE: 0x0000001c EXCVADDR: 0x80086f5c LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x400833ab EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x400833ab:0x3ffc0260 0x40086f59:0x3ffc0280 0x40087c8d:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40106dd0: 10669a29 66604044 80686a81 Core 1 register dump: PC : 0x40106dd4 PS : 0x00060031 A0 : 0x80087c90 A1 : 0x3ffc0280 A2 : 0x3ffbe028 A3 : 0x20000000 A4 : 0x00000400 A5 : 0x3ffb1c10 A6 : 0x3ffb1cc4 A7 : 0x8acd64e9 A8 : 0x80086f5c A9 : 0x3ffc0260 A10 : 0x3ffb8b2c A11 : 0x3ffb81cc A12 : 0x22137607 A13 : 0x10325476 A14 : 0xc0e80300 A15 : 0xeb31264e SAR : 0x00000012 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x40106dd4 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40106dd4:0x3ffc0280 0x40087c8d:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x40135d5d:0x3ffb1d00 0x40135dc6:0x3ffb1d20 0x4013792a:0x3ffb1d40 0x40137a60:0x3ffb1d60 0x40135d4e:0x3ffb1d80 0x4013305f:0x3ffb1da0 0x40162f05:0x3ffb1dc0 0x400dd93d:0x3ffb1e00 0x400dde08:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 1 register dump: PC : 0x00ffe746 PS : 0x00060031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000000 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x80087c90 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8 A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x00000014 EXCVADDR: 0x00ffe744 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x00ffe746 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x00ffe746:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cd8: 580c8920 e2192102 28200588 Core 1 register dump: PC : 0x40087cdf PS : 0x00050031 A0 : 0x3ffc7cfc A1 : 0x3ffc02a0 A2 : 0x00000003 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3ff60000 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8 A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x40087cdf EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~~ Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cd8: 580c8920 e2192102 28200588 Core 1 register dump: PC : 0x40087cdf PS : 0x00050031 A0 : 0x3ffc7cfc A1 : 0x3ffc02a0 A2 : 0x00000001 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3ff60000 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffbcef8 A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 1 was running in ISR context: EPC1 : 0x40087cdf EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60 Rebooting... f~f~ Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 1 register dump: PC : 0x00ffe746 PS : 0x00060031 A0 : 0x4008e5f0 A1 : 0x3ffc02a0 A2 : 0x00000000 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x3f40c770 A7 : 0x49f253b1 A8 : 0x80087c90 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffb1c60 A14 : 0x3ffb1cc4 A15 : 0x3ffb1c8c SAR : 0x00000014 EXCCAUSE: 0x00000014 EXCVADDR: 0x00ffe744 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x00ffe746 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x00ffe746:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x40135d51:0x3ffb1d20 0x4013792a:0x3ffb1d40 0x40137a60:0x3ffb1d60 0x40135d4e:0x3ffb1d80 0x4013305f:0x3ffb1da0 0x40162f05:0x3ffb1dc0 0x400dd93d:0x3ffb1e00 0x400dde08:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40087cd8: 580c8920 e2192102 28200588 Core 1 register dump: PC : 0x40087cdf PS : 0x00050031 A0 : 0x3ffc7cfc A1 : 0x3ffc02a0 A2 : 0x00000000 A3 : 0x00000001 A4 : 0x000000ff A5 : 0x400947a8 A6 : 0x00000000 A7 : 0x0a7fb73a A8 : 0x3ff60000 A9 : 0x3ff5f000 A10 : 0x3ffbe028 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x3ffb1b90 A14 : 0x00000000 A15 : 0xf4516150 SAR : 0x0000001e EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Core 1 was running in ISR context: EPC1 : 0x40087cdf EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008ed72 ELF file SHA256: 0000000000000000 Backtrace: 0x40087cdf:0x3ffc02a0 0x3ffc7cf9:0x3ffc02c0 0x4015f673:0x3ffb1c90 0x4015e711:0x3ffb1cf0 0x4015ec4d:0x3ffb1d30 0x4012e3c6:0x3ffb1d50 0x4012e52e:0x3ffb1d90 0x4012e555:0x3ffb1db0 0x400eedff:0x3ffb1dd0 0x400eef17:0x3ffb1df0 0x40154cf9:0x3ffb1e10 0x400dde79:0x3ffb1e30 0x400d6ae3:0x3ffb1f30 0x400d6c31:0x3ffb1f70 0x400d4a97:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0 Rebooting... f~f~ Core 0 register dump: PC : 0x40087a1c PS : 0x00060830 A0 : 0x800da768 A1 : 0x3ffb3ec0 A2 : 0x00000023 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001 A6 : 0x00060820 A7 : 0x00000000 A8 : 0x00002a00 A9 : 0x829a8a08 A10 : 0x00002a00 A11 : 0x829a8a8c A12 : 0x00060820 A13 : 0x00000001 A14 : 0x00060823 A15 : 0x00000000 SAR : 0x0000001d EXCCAUSE: 0x0000001d EXCVADDR: 0x829a8a8c LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000 Backtrace: 0x40087a1c:0x3ffb3ec0 0x400da765:0x3ffb3ee0 0x400dac65:0x3ffb3f00 0x400da409:0x3ffb3f40 0x400d5daa:0x3ffb3f80 0x40081a4d:0x3ffb3fc0 0x400920c2:0x3ffb3fe0 Rebooting... f~x��xx
��~ffffff`ff��~
A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000012 EXCCAUSE: 0x00000000
Rebooting…
f~f~
ok:start
PC : 0x40087b56 PS : 0x00060430 A0 : 0x800d21d8 A1 : 0x3ffb1ed0
A2 : 0x3ffde218 A3 : 0x000000dd A4 : 0x00003a98 A5 : 0x00000281
A6 : 0x80000000 A7 : 0x00000bfd A8 : 0x80087b56 A9 : 0x3ffb1eb0
A10 : 0x00000281 A11 : 0x00000000 A12 : 0x00000281 A13 : 0x0000c600
A14 : 0x3ffbdd3f A15 : 0x3ffbdd3d SAR : 0x0000000a EXCCAUSE: 0x00000000
Backtrace: 0x40087b56:0x3ffb1ed0 0x400d21d5:0x3ffb1ef0 0x40081d53:0x3ffb1f50 0x400d4aae:0x3ffb1f90 0x400ebbc1:0x3ffb1fb0 0x400920c2:0x3ffb1fd0
Rebooting…
f~f�x
A6 : 0x00000000 A7 : 0xf683bbea A8 : 0x3ff60000 A9 : 0x3ff5f000
Rebooting…
f~f~�xx
Rebooting…
f~f~�xx
PC : 0x400878d7 PS : 0x00060530 A0 : 0x800e9957 A1 : 0x3ffb1e40
A2 : 0x00000024 A3 : 0x000000c0 A4 : 0x00060320 A5 : 0x00000000
A6 : 0x00060923 A7 : 0x00000000 A8 : 0x3f4033b0 A9 : 0x000000c0
A10 : 0x00000008 A11 : 0x00000004 A12 : 0x3ffaff60 A13 : 0x00000001
A14 : 0x00060923 A15 : 0x00000000 SAR : 0x0000001c EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000008 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x400878d7:0x3ffb1e40 0x400e9954:0x3ffb1e60 0x400e998e:0x3ffb1e80 0x400e9a5d:0x3ffb1eb0 0x400d2fd0:0x3ffb1ef0 0x4008591d:0x3ffb1f20 0x4008187a:0x3ffb1f60 0x400d4a91:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0
Rebooting…
ff~
PC : 0x400878b7 PS : 0x00060730 A0 : 0x800d3938 A1 : 0x3ffb1ef0
A6 : 0x00060520 A7 : 0x00000000 A8 : 0x11100129 A9 : 0x00000000
A10 : 0x00002a00 A11 : 0x3ff4901c A12 : 0x00400000 A13 : 0x3ffb4000
A14 : 0xffffffff A15 : 0x00000000 SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x11100129 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x400878b7:0x3ffb1ef0 0x400d3935:0x3ffb1f10 0x400d4992:0x3ffb1f30 0x400817bf:0x3ffb1f60 0x400d4a91:0x3ffb1f90 0x400ebbb2:0x3ffb1fb0 0x400920c2:0x3ffb1fd0
Rebooting…
f~f~
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00060023 A5 : 0x400947a8
A10 : 0x00000000 A11 : 0x3ffbcb00 A12 : 0x00060023 A13 : 0x3ffbcef8
Backtrace: 0x40087c37:0x3ffc02a0 0x4008e5ed:0x3ffc02c0 0x4018db57:0x3ffbce00 0x40156907:0x3ffbce20 0x40093871:0x3ffbce40 0x400920c2:0x3ffbce60
Rebooting…
f~f~
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00060520 A7 : 0x00000000 A8 : 0x3f402ccc A9 : 0x4a000000
A10 : 0x3ff48498 A11 : 0x00000044 A12 : 0x4a000000 A13 : 0x3ffb4000
Rebooting…
f~f~
ok:start
time out 1s
time out 1s
time out 1s
time out 1s
time out 1s
M2001 0.0.0.0
PC : 0x40087b56 PS : 0x00060830 A0 : 0x80081d05 A1 : 0x3ffb1f30
A2 : 0x00000001 A3 : 0x00000080 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x3ffbdbb4 A7 : 0x3ffc74a4 A8 : 0x80087b56 A9 : 0x3ffb1f10
A10 : 0x00000391 A11 : 0x00000000 A12 : 0x00000391 A13 : 0x00004640
A14 : 0x80000000 A15 : 0x00000bfe SAR : 0x0000000a EXCCAUSE: 0x00000000
Backtrace: 0x40087b56:0x3ffb1f30 0x40081d02:0x3ffb1f50 0x400d4aae:0x3ffb1f90 0x400ebbc1:0x3ffb1fb0 0x400920c2:0x3ffb1fd0
Rebooting…
f�~
