Lightburn Issues Stopping During Jobs
I have a Creality Falcon Pro 10W laser and I’ve had issues with the Lightburn jobs halting a couple of seconds into the job. The laser will start and then stop, but the timer is still running as if it was operating.
I also noticed that certain power/speed will cause it to stop. When copying the artwork to a new layer and using default settings (6000/mm min @ 20%) - it seems to work fine. If these settings don’t work, I have to turn off the machine and reconnect it.
I’m new to Lightburn and all the commands/console and I was hoping someone could help me out. I can start a job and send over any data/errors from the console and/or send screenshots of my Lightburn settings.
Thanks so much, I appreciate any help.
Help us see what you’re seeing. Copy and paste the contents of the Console window when the job fails. Please post a screenshot of your entire Lightburn screen with your project loaded and the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
themuth, thank you for responding and your time - very much appreciated. Attached are the screenshots and I included the console data below.
This is setup for rotary, but the same issues happen with rotary disabled and I’m engraving something flat, too.
  1. Once I started the job, the machine beeped at me and failed right after the start.
  2. To unfreeze the machine, I clicked “Stop” and then reframed. Copied the artwork to a new layer (C14)
    and used the default speed/cut settings.
  3. I reframed and then started the job. It worked fine.
  4. I stopped it in the middle, and changed the settings
Screenshots:
![Screenshot (4)|690x388 (upload://thxmo7OMoRQQYIeUUO3DDexPyeG.png)
Console data:
Waiting for connection…
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xb (SPI_FAST_FLASH_BOOT)
Saved PC:0x4037f696
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3810,len:0x3b8
load:0x403c9700,len:0x9a4
load:0x403cc700,len:0x251c
entry 0x403c9868
[OK]system start-up CV30-Pro-MASTER-Release V1.0.0 20230921-0947
MC3416 Init OK (0x4c:-1,0x6c:0)
[OK] gas_init OK
usb connect succeed
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
ok
ok
[VER:1.1f.20220810:]
[OPT:VHL,127,65536]
Target buffer size found
[software versions: CV30-Pro-MASTER-Release V1.0.0 20230921-0947]
ok
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
Project loaded in 1 milliseconds
<Idle|MPos:0.000,0.000,0.000|Bf:127,65535|FS:0,0|Pn:X|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:02
<Idle|MPos:0.000,0.000,0.000|Bf:127,65535|FS:0,0|Ov:100,100,100|A:S>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:127,65535|FS:0,0>
ok
ok
ok
Starting stream
ok
Starting stream
Stream completed in 0:03
ok
Starting stream
Starting stream
Layer C02
ERROR:01.
The angle data isok
abnormal and it has stopped worok
king.
Please restore the maok
chine to its original location and restart the machine.
Pleok
ase refer to the in the TF card for the video tutorial link
Tutorial Link:
Stream completed in 1:31
ok
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,0.000,0.000|Bf:127,65535|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
ok
Starting stream
Starting stream
Layer C14
Stream completed in 0:10
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
Starting stream
[MSG:Pgm End]
ok
Starting stream
ok
Starting stream
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
ok
Starting stream
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Most of the time Alarm 3 is caused by communication issues, i.e. a bad USB Cable. The cables that come with the machines are often not of the highest quality. I would suggest trying a good quality USB cable first. One with the ferrite cores on the ends and see if that resolves your issue.
Occasionally there is a large power drain on the same circuit which could also cause issues, or electromagnet interference from a motor running nearby. Think table saw or refrigerator. But a good cable usually prevents those issues as well.
Thank you so much. I’ll get a new cable and check for the power/interferences.
