Lightburn keeps showing busy after cutting
Hi all. Have an Atomstack A20 Pro - swapped the laser module for a Lasertree 40W module.
Changed $30 s max to 1000 in lightburn and machine settings.
Two things happen
1 at 100% power laser will not cut, goes to start then freezes, then has to be stopped and homed.
2 at 60% power laser will cut but when finished and homing laser shows busy and has to be switched off to reset it.
Any help to sort this would be appreciated. Thank you.
At 60% it runs, sort of. Did you upgrade the power supply to one with a higher capacity? That 40w module needs a lot more current.
Seems your advice to look at the power supply worked. Am using the separate power supply that came with Lasertree module for the laser module itself and so far no problem. Thank you.
