Lightburn keeps stopping in middle of a process
I am using Lightburn to make a tile picture that should take about 3hrs to burn. At the 41:26 mark it stops the process and then homes. This just started today. I’ve tried on 2 separate files and the same thing. I’m runnint an Ortur LM2 15W
If it’s re-homing, that’s a USB disconnection / reconnect, which is most likely caused by a loose cable or port connection, or possibly a power brownout. I would check the USB connection is not loose at all on either the Ortur side or the computer side, and the power connection is secure as well.
Thanks. I’ve plugged in to a different USB port, rechecked all connections and re-installed Lightburn. So far so good. It’s got 5 hours on it today.
