Lightburn Laser Button doesn’t work
Hi peeps,
I am wondering if you can help me with a laser engraving program?
My teacher has a program with using the Lightburn Software. We have been trying for 2 hours with the coding. But we both are not familiar with coding.
Issue stated as below:
We could see the picture on the software and we could see the « laser » tab
We could click on starting the laser but then nothing happened
The laser was shown but didn’t move and didn’t engrave anything
When you click on ‘Frame’, do you see a red rectangle around your job?
Has this galvo worked before? Or are you setting it up for the first time?
The image looks very small, it may be easier to make it larger, or get rid of it and just start with some text using the text tool in LightBurn.
This video runs through some of the basics:
LightBurn For Galvo - First Project
Is the lens cap removed and the lens focussed?
Hi Nicholas,
Yes, this is lens focused. And it is our first setting it up.strong text
Can you confirm if you are able to frame the job to verify that the job is positioned correctly over the black card?
