Have you ever had a problem where you had several pieces cut and after a while the laser head no longer moves, but the laser beam cuts, I have a sculpfun s30 ultra and I had about 20 pieces cut, the cutting time is still working but the head does not move
You do not give us much to work with to get a solution. Maybe upload the Lightburn file so others can examine it.
In the mean time, are you using the Preview window? Fast forward (slider) about 20 pieces, then run it at 1x speed and watch for something funky.
This is usually caused by a bad usb connection and / or bad power lines. I’d first try to exchange the usb cable and then the power supply.
Hello,
thanks for the replay,I probably have a voltage problem, I have 4 devices on one outlet, I will distribute the electronic devices.
