I have a JPT 60W MOPA, my Lightburn has no materials library, does anyone know where I can get one or can some one pass it to me? Specifically, when using Lighburn, you create a layer/material setting in your library and that creates a (.clb) file. That file is all of the settings for materials. This file can be shared and used by others. For example, if your library has Stainless Steel, Aluminum, Wood, that file when uploaded on my machine would show all those settings. Thank you for your time in advance. I do realize this is just a starting point. Respecfully, Sean
man, I so miss my fiber lasers ![]()
I actually saw this as an opportunity to test out the new ChatGPT 4.0… Mind letting me know if this list makes sense?
| Material | Depth | Power | Frequency | Speed | Gas |
| Stainless Steel | 0.1mm | 25W | 30 kHz | 500 mm/s | N/A |
| Stainless Steel | 0.25mm | 30W | 25 kHz | 400 mm/s | N/A |
| Stainless Steel | 0.5mm | 40W | 20 kHz | 300 mm/s | N/A |
| Aluminum | 0.1mm | 20W | 35 kHz | 600 mm/s | N/A |
| Aluminum | 0.25mm | 25W | 30 kHz | 450 mm/s | N/A |
| Aluminum | 0.5mm | 35W | 25 kHz | 350 mm/s | N/A |
| Brass | 0.1mm | 20W | 35 kHz | 550 mm/s | N/A |
| Brass | 0.25mm | 25W | 30 kHz | 400 mm/s | N/A |
| Brass | 0.5mm | 35W | 25 kHz | 300 mm/s | N/A |
| Acrylic | 0.1mm | 15W | 40 kHz | 700 mm/s | Air |
| Acrylic | 0.25mm | 20W | 35 kHz | 500 mm/s | Air |
| Acrylic | 0.5mm | 30W | 30 kHz | 400 mm/s | Air |
| Anodized Aluminum | 0.1mm | 15W | 40 kHz | 600 mm/s | N/A |
| Anodized Aluminum | 0.25mm | 20W | 35 kHz | 450 mm/s | N/A |
| Anodized Aluminum | 0.5mm | 25W | 30 kHz | 350 mm/s | N/A |
| ABS Plastic | 0.1mm | 10W | 45 kHz | 800 mm/s | Air |
| ABS Plastic | 0.25mm | 15W | 40 kHz | 600 mm/s | Air |
| ABS Plastic | 0.5mm | 20W | 35 kHz | 450 mm/s | Air |
| Wood | 0.1mm | 10W | 45 kHz | 900 mm/s | Air |
| Wood | 0.25mm | 15W | 40 kHz | 700 mm/s | Air |
| Wood | 0.5mm | 25W | 35 kHz | 500 mm/s | Ai |
| Material | Thickness | Power | Frequency | Speed | Gas |
| Stainless Steel | 0.1mm | 20W | 30 kHz | 600 mm/s | N/A |
| Stainless Steel | 0.25mm | 25W | 30 kHz | 450 mm/s | N/A |
| Stainless Steel | 0.5mm | 30W | 25 kHz | 300 mm/s | N/A |
| Aluminum | 0.1mm | 15W | 35 kHz | 700 mm/s | N/A |
| Aluminum | 0.25mm | 20W | 30 kHz | 500 mm/s | N/A |
| Aluminum | 0.5mm | 30W | 25 kHz | 350 mm/s | N/A |
| Brass | 0.1mm | 15W | 35 kHz | 650 mm/s | N/A |
| Brass | 0.25mm | 20W | 30 kHz | 450 mm/s | N/A |
| Brass | 0.5mm | 30W | 25 kHz | 300 mm/s | N/A |
| Acrylic | 0.1mm | 10W | 40 kHz | 900 mm/s | Air |
| Acrylic | 0.25mm | 15W | 35 kHz | 700 mm/s | Air |
| Acrylic | 0.5mm | 20W | 30 kHz | 500 mm/s | Air |
| PETG | 0.1mm | 10W | 40 kHz | 800 mm/s | Air |
| PETG | 0.25mm | 15W | 35 kHz | 600 mm/s | Air |
| PETG | 0.5mm | 20W | 30 kHz | 400 mm/s | Air |
| PVC | 0.1mm | 10W | 40 kHz | 800 mm/s | Air |
| PVC | 0.25mm | 15W | 35 kHz | 600 mm/s | Air |
| PVC | 0.5mm | 20W | 30 kHz | 400 mm/s | Air |
| Thin Paper/Card | 0.1mm | 5W | 50 kHz | 1500 mm/s | Air |
| Thin Paper/Card | 0.25mm | 10W | 45 kHz | 1000 mm/s | Air |
| Thin Paper/Card | 0.5mm | 15W | 40 kHz | 700 mm/s | Air |
Do you think ChatGPT4 could do a material library for the Ortur Laser Master 2 Pro S2?
Alright, second try. Posting on mobile was messing everything up. So it’s interesting because the settings vary each time I ask for it, and are different based on the format output (text vs table), but they don’t seem like they’re too crazy… so possibly a good starting point?
Here are a few answers.
- Birch plywood (engraving):
- Power: 70-80%
- Speed: 200-300 mm/min
- Passes: 1-2
- Cherry plywood (engraving):
- Power: 70-80%
- Passes: 1-2
- Maple plywood (engraving):
- Power: 70-80%
- Passes: 1-2
- Paper (cutting):
- Power: 20-40%
- Speed: 500-1000 mm/min
- Passes: 1
- Cardboard (cutting):
- Power: 40-60%
- Speed: 200-500 mm/min
- Passes: 1-2
| Material | Engraving Power | Engraving Speed | Cutting Power | Cutting Speed | Passes (Cutting) |
| Birch Ply | 60-70% | 100-200 mm/s | N/A | N/A | N/A |
| Cherry Ply | 60-70% | 100-200 mm/s | N/A | N/A | N/A |
| Maple Ply | 60-70% | 100-200 mm/s | N/A | N/A | N/A |
| Balsa | 30-40% | 200-300 mm/s | N/A | N/A | N/A |
| Leather | 40-60% | 150-250 mm/s | N/A | N/A | N/A |
| Corrugated Cardboard | 40-50% | 200-300 mm/s | 50-70% | 50-100 mm/s | 1-3 (depending on thickness) |
| Paper | N/A | N/A | 10-20% | 200-300 mm/s | 1-2 (depending on thickness) |
| Cardboard | N/A | N/A | 40-60% | 100-200 mm/s | 1-2 (depending on thickness) |
I was discussing Chat GPT with a friend of mine who is in Software. She warned me that AI Chat technology is often “Confidently wrong.”
Please use the Materials test tool to find your cut settings.
I offer this Chat GPT result for your consideration.
I wouldn’t fault you if you weren’t a car guy and didn’t get the joke.
Oh I’m well aware that ChatGTP often spews nonsense, but I just used it to write a 15k word document in a single day. Took a lot of babysitting and corrections, but overall it was surprisingly right. It also improved the firmware memory efficiency on a project I was working on by reducing consumed memory by 3% (important on an arduino chip). I’m really curious to see how close or far off the mark these recommendations are.
Thank you all for the posts, I do appreciate it! I should make my question a little clearer. When using Lighburn, when you create a setting in your library it starts creating a (.clb) file. That file is all of the settings for materials. Specifically, for those of you using a Fiber Laser and Lightburn I am looking for a copy of that. Some of you folks have been using it for multiple years and have built up a wealth of knowledge that I am trying to learn from using that file. If anyone can share that it would be great!!! Sean
This list does make sense to a degree. It’s missing some data I am looking for when talking MOPA like pulse time that sort of things. I am also looking for things like annealing settings. Thank you for taking the time. Sean
