Licensed copy of Ligthburn with the update button off tries to connect to a11b2229884c17d9d.awsglobalaccelerator.com what are your thoughts?
This is Amazon AWS equivalent of Cloud Flare, which I assume Lightburn uses as hosting.
You are just seeing which caching servers the packets are routing through.
What’s the problem exactly?
Before buying Lightburn talked with support and they said Ligtburn only connects for registering after that stays offline.
Fernando
I am not able to replicate what you are experiencing
lightburn.exe does not seem to be making any IPV6 or IPV4 connection to the IPs or domains you said.
Maybe its above my brain paygrade though.
@JohnJohn might clarify
Edit, actually i must correct myself, my update speed was too small
Still dont know exactly what it means
If it’s not connecting as expected, I’d like to take a look at the Hosts file.
Please follow the steps, open the Hosts file and share what you are seeing.
No! It`s trying to connect as unexpected.
Fernando
