Having an issue with Lightburn crashing, usually it happens while the computer is connected to the laser. After making a cut if I go back to the computer it is locked up and I have to close the program and restart the laser. Today while working on a design it crashed continually. I have a brand new computer which should handle the program easily. After reading through several forum posts I found where a call stack should be captured. Just looking to see if anyone else is having the same issue. I am getting a not responding error and the whole screen dims.
Anyone have any idea what’s going on with this crashing I described. Thanks
Mac? Windows? Windows 11?
Need more info.
Windows 11 pro 12th gen intel i9, 64 gb RAM, 64 bit operating system. Nvidia RTX A5500 graphics card
Okay so it just crashed again. I ran a job on the laser and it was fine. When I went back to make the final design change I went back to the program and it was froze up, It displayed the not responding error. I ran the process explorer and this is what the call stack shows.
ntoskrnl.exe!KeSynchronizeExecution+0x7db6
ntoskrnl.exe!KeLowerIrql+0x2235
ntoskrnl.exe!KeLowerIrql+0x3657
ntoskrnl.exe!KeWaitForSingleObject+0x256
ntoskrnl.exe!KeQuerySystemTimePrecise+0xa13
ntoskrnl.exe!KeSetActualBasePriorityThread+0x63e
ntoskrnl.exe!KeLowerIrql+0x265a
ntoskrnl.exe!ObWaitForSingleObject+0xcc
ntoskrnl.exe!NtWaitForSingleObject+0x6b
ntoskrnl.exe!setjmpex+0x8cd5
ntdll.dll!NtWaitForSingleObject+0x14
KERNELBASE.dll!WaitForSingleObjectEx+0x8e
Qt5SerialPort.dll!QSerialPortInfo::isValid+0x1803
Qt5SerialPort.dll!QSerialPort::handle+0x1b1c
LightBurn.exe+0x1d97a4
LightBurn.exe+0x49d31b
LightBurn.exe+0x49d5f9
LightBurn.exe+0x4a48da
LightBurn.exe+0x48548e
LightBurn.exe+0x4da51a
LightBurn.exe+0x4f70e4
Qt5Core.dll!QMetaObject::activate+0x641
Qt5Widgets.dll!QAction::activate+0x10e
Qt5Widgets.dll!QAbstractButton::click+0x143
Qt5Widgets.dll!QAbstractButton::mouseReleaseEvent+0x8c
Qt5Widgets.dll!QToolButton::mouseReleaseEvent+0xf
Qt5Widgets.dll!QWidget::event+0xdc
Qt5Widgets.dll!QApplicationPrivate::notify_helper+0x140
Qt5Widgets.dll!QApplication::notify+0x8c3
Qt5Core.dll!QCoreApplication::notifyInternal2+0xb9
Qt5Widgets.dll!QApplicationPrivate::sendMouseEvent+0x3f3
Qt5Widgets.dll!QSizePolicy::QSizePolicy+0x2aa5
Qt5Widgets.dll!QSizePolicy::QSizePolicy+0xb1b
Qt5Widgets.dll!QApplication::notify+0x1b6d
Qt5Gui.dll!QGuiApplicationPrivate::processMouseEvent+0x9ab
Qt5Gui.dll!QWindowSystemInterface::sendWindowSystemEvents+0x92
Qt5Core.dll!QEventDispatcherWin32::processEvents+0xde6
USER32.dll!DispatchMessageW+0x741
USER32.dll!DispatchMessageW+0x201
Qt5Core.dll!QEventDispatcherWin32::processEvents+0x5b0
qwindows.dll!qt_plugin_query_metadata+0x1db9
Qt5Core.dll!QEventLoop::exec+0x1cb
Qt5Core.dll!QCoreApplication::exec+0x141
LightBurn.exe+0x4b3f89
LightBurn.exe+0x4b4039
LightBurn.exe!FT_WriteEE+0x2b5ef4
LightBurn.exe!FT_WriteEE+0x2b4bfb
KERNEL32.DLL!BaseThreadInitThunk+0x1d
ntdll.dll!RtlUserThreadStart+0x28
Anyone have any idea what is going on here. I’m sure its a simple fix but I cant find it
Thank you
I also ran reliability monitor on the laptop and this is the explanation given for the crash.
Description
A problem caused this program to stop interacting with Windows.
Faulting Application Path: C:\Program Files\LightBurn\LightBurn.exe
Problem signature
Problem Event Name: AppHangB1
Application Name: LightBurn.exe
Application Version: 0.0.0.0
Application Timestamp: 6398c78d
Hang Signature: 03fe
Hang Type: 134217728
OS Version: 10.0.22621.2.0.0.256.48
Locale ID: 1033
Additional Hang Signature 1: 03feeb0e63d208d586ac8a3666dfc424
Additional Hang Signature 2: 74aa
Additional Hang Signature 3: 74aa6384a3606c3cb6dba8489a44f2c5
Additional Hang Signature 4: 03fe
Additional Hang Signature 5: 03feeb0e63d208d586ac8a3666dfc424
Additional Hang Signature 6: 74aa
Additional Hang Signature 7: 74aa6384a3606c3cb6dba8489a44f2c5
Extra information about the problem
Bucket ID: cfa73de05d06f5cc5eed9c734c7c5b99 (2228609409636653977)
Thank you for reporting this.
LightBurn shouldn’t crash.
I have shared this with the Dev team internally and we will attempt to replicate the hang. Are you willing to share the LBRN or LBRN2 file?
If so, you can post it here or email it to Support@LightBurnsoftware.com with a link to this forum thread and a note so we can follow this up right away.
JohnJohn,
Sure no problem. I sent the email it to the support email with the link and the file.
Thank you.
I’ve never seen this before - The file is not complex enough to cause any problems, and the call stack you provided is showing that it’s hung up querying the serial port to see if it’s valid.
Can you re-run the LightBurn installer, and check the box at the end to install the FTDI driver? That’s the one used by the chip in Ruida controllers - I’m wondering if perhaps you installed a bad driver, or the one you have got corrupted somehow.
I can try that however that was done already at the request of Aeon.
Here is the other crashes I recorded maybe they will help.
ntoskrnl.exe!KeSynchronizeExecution+0x469c
LightBurn.exe+0xd1f08
LightBurn.exe+0xa8547
LightBurn.exe+0xd0af6
LightBurn.exe+0x353d62
LightBurn.exe+0x353375
LightBurn.exe+0x4e12e9
LightBurn.exe+0x4da591
LightBurn.exe+0x13d8f
LightBurn.exe+0xd1edc
LightBurn.exe!FT_WriteEE+0x2b5c9c
LightBurn.exe+0xa862a
LightBurn.exe+0xd1f0b
LightBurn.exe+0xd1eaf
Every one of those crashes is in that function, which is part of the Windows NT kernel (IE, the low-level operating system code).
If I was a betting man, I’d say there’s a decent possibility that something in Windows itself is corrupted. Do you have any other computers you can try this on? I assume this is Windows 10?
I do not have another computer to try, my last one was 12 years old. Actually it is a brand new Dell 7770 running Windows 11 Pro. Should I try a reinstall of windows?
I hate to suggest it, but honestly it’s worth a shot, yes.
Actually did it last night. Now we shall see what happens
