Current version of LB on a Mac Running Ventura with a ComMarker B4/30watt Fiber laser and a XTOOL RA2 Chuck Rotary. I have the settings to return to center after the burn, but it never does. It’s stuck on Framing in the “READY etc” spot and I have to either quit LB or turn off the Fiber laser to get it to reset so it shows ready.
Your time and assistance are greatly appreciated,
Matt Caswell
My rotary has been configured based on the stepper motor, all switches set correctly. It tests 360° perfectly around and back. It burns perfectly, it just won’t return to center and is stuck on Framing.
Thanks for taking the time to respond with your questions.
Matt
Yes I have it set, on the fiber laser Galvo there is no option for user origin etc. But there is a setting to return to start which would be the center of the design.
But it doesn’t return to the original position. It just stops at the end of the burn and says “Framing”. Here you can see the position it stopped at and in the control panel you can see it’s done but says “FRAMING”
at the end of the burn, you can see that it sliced all 3445 and just quit burning and never returned to the starting point. Perhaps this feature Doesn’t work on Fiber lasers?
Maybe since the center is 64mm, when it finishes on the left edge, the position is “0”. I’m smart on Diode and LB, but I’m LB stupid on Fiber lasers I guess.
Your answer is what I thought. I have rotary/ fiber so that is not the problem, it behaves exactly like you wuld expect, finishes the burn and returns to zero. In your case it is clearly stopping prior to returning to zero. Have you tried something with less slices and / or a larger split size? 3445 is not that much, but curious if it is a memory issue. I have maxed memory out with LB, it usually resolves after a bit and continues on, doesn’t freeze up forever. Is there any other software open?
I’m wondering if it’s the fact that I’m using the XTOOL RA2 rotary which is made for their Diode lasers. It works great except for the fact that it won’t return to start. I never have that issue when using the RA2 on my XTOOL D1 20w Diode.
One other thing to mention. I used one of my RA2 rotaries in a vertical mode to do 8 biz cards on a horizontal jig and it does all 8, then returns to start, but using REPEAT Marking doesn’t have me enable rotary even though it uses it.
I doubt it is a problem with the rotary, especially if it returns correctly during test. They are such a simple device. Here is something to try if you haven’t, turn off “Return to Start” Run a small test vector, and then see if the “go to zero” button works or if it is still locked up. I think it is likely a software conflict or something like that.
