Lightburn only printing partial
Not sure why it is cutting some files incomplete. Happens if I import a file or generate text in Lightburn. Ortur laser- GRBL-M3
If you’re running in ‘Absolute Coords’ mode, LightBurn defaults to only sending things to the laser that are within the bounds of your workspace, so it doesn’t crash the laser. Could that be what’s happening?
If so, you can disable the check in the Device Settings here:
