Hello everyone… I have one problem :-)… I have pdf format file… In that file there are some shape i need to trace it and cut it… Whenever i printscreen it and paste it to lightburn to trace picture everytime program trace 2 line… Why is that… I try bigger/smaller format, screen it in different way alway show two line…
how can i trace only one line ?
I think the trace tool is supposed to trace outlines right? With that, the lines have 2 sides so I’m not sure any program could automatically select which sides to trace and which ones to ignore on a per user basis. If there’s other options I don’t know it but you can select which pieces you don’t want and delete them. Alternatively you could use Fill instead of Line but it would probably take longer.
LightBurn does not provide a ‘Center-line’ trace at this time. It has been suggested, so you can add your support here:
There are options for other software that provides such, like InkScape, or you could use the ‘Offset’ tool in LightBurn to produce the center line from the trace results.
