Using Pro but the console output is blank.
Even if no laser is connected, there should be text in that window. Does it show anything at all?
What laser are you using? I see in your profile that you have a GRBL machine, that doesn’t require Pro. Are you using a different laser type?
Using Monport 90w co2 with a Ruida controller.
It could make sense that your Ruida machine, which does not speak GCode but instead a proprietary protocol, does not have anything to say in the serial console. So, is there any problem that you are experiencing that we can help you with?
No console output on a DSP driven machine with Ruida controller
