I have the Lightburn core license for several months already, using it for my diode lasers. I will soon receive the CO2 laser (Ruida controller) that I just recently ordered, and I want to know if there is a way to access the trial version of the pro license to test it out on the new machine?
I want to make sure that the pro version works perfectly on the machine before I make the upgrade.
Thank you!
add
I’m thinking of deactivating my license and run the trial version, but I’m not sure if I am still eligible to use the trial since I have already used the 30-trial period before purchasing the license.
I’d say just use another machine / laptop and install LB there. Or create a VM inside your current machine. I guess LB should run fine then for 30 days.
This sounds like a great solution. Thank you! Finding or borrowing another laptop/computer is an easier problem to solve. I will probably stick to this, less headaches for me.
To test out Pro support, you can also deactivate your license key from the license management page and extend your free trial by clicking the Extend Trial button. This button appears in versions 1.5+:
If you are unable to extend your trial by clicking this button, email your trial ID number to support@lightburnsoftware.com
