Getting very poor results with Lightburn with
xtool D1 laser.
I get excellent quality when using XCS, but love the features lightburn has to offer. But I have yet to be able to get any decent results.
Attached is an image of the text I’ve tried burning on a metal business card. The clear and concise text is from XCS, and the blurry is from Lightburn. All same font, size and burn settings.
Did you create the laser device profile by using the .lbdev file provided xTool? If not, suggest you do that and retest. The .lbdev file provided by xTool includes offset scanning adjustments that should remedy what you’re seeing.
Here are several shots. Let me know if there is anything else. Another note, the picture of the bear will print excellent in XCS, but horrible in Lightburn.
I’m not seeing anything fundamentally wrong in the screenshots. But now I’m questioning the original set of symptoms on whether or not I’ve understood it properly.
A few questions:
Are you using like for like settings in XCS vs LightBurn? One thing about the cut settings in LightBurn is that the speed is quite high although not absurdly so. The fill density is almost certainly higher than ideal at 500 lines per inch (I’d guess by close to 2x) but shouldn’t cause what I thought I saw in the initial photos.
Can you run a test burn with the following parameters:
2a. .5 inch square or larger
2b. fill mode
2c. .04 inch line interval or higher
2d. bidirectional
Run a test burn of a circle at least .5 inch in line mode
The results reflect some of what I expected but are not exactly consistent to what I would expect.
Reviewing your settings I see a problem that could be skewing the results so could you run it again. However, in the Line test, can you disable “Tabs Bridges”? It’s potentially obscuring root cause.
