LIghtburn Projects inverting from one computer to the next
Hello. I have Lightburn installed on 2PCs. The one in my workshop which controls the laser, and one in my home office simply for designing when I’m too lazy to walk outside to the shop (or it’s too cold). However, if I create a design on one machine and try to open it on another, the second machine will invert the image. What’s going on with that? BTW, I noticed this after the last Lightburn update.
Thanks in advance
Do you possibly have the origin set in different locations between the two conputers? My images were being inverted due to incorrectly set origin. Hope this helps!
Did you copy the configuration files from the shop PC to the office PC (or the other way around)? If not, then they likely have different devices & settings.
The doc helps you transfer all you need:
