Hi.
I’m unable to create a QR code using Lightburn built in QR code generator that contains both WIFI along with URL. Any ideas how to accomplish this? Tried it several times but cannot make it work with both WIFI and an URL to create one integrated QR Code.
Is it possible to just type the URL in the first tab manually and add WIFI info in the WIFI tab? Any feedback is greatly appreciated. Thanks in advance!
I don’t believe the wifi QR standard allows for an arbitrary URL field which is why you’re likely struggling with this.
If you wanted to move away from de facto standards you could create a custom QR code that adds a URL field to recognized wifi fields but whether or not client applications would work correctly is going to be implementation specific.
Maybe type in your first info then select it again and right click on edit QRcode select wifi.
