Lightburn remembers the last name used for that layer/color
For each layer/color, Lightburn remembers the last name used for that layer/color.
I find this annoying. Is there a way to turn this off?
in Edit/Settings Starting in 0.9.15 I believe:
Where do I check which version I have?
I see nothing under Help
Upper left hand corner of the LightBurn screen: image
I got a dot
screenshot-lightburn
Help → Quick help & notes → About
Steve - Your curve tolerance value is really high. That should be about 0.05mm (the default) - it controls the precision of curves sent to the machine.
You’re apparently using Linux, which doesn’t show the version number in the application title. The Help > Quick Help and Notes > About tab that Hank pointed you to will tell you the version number.
Oz,
Thanks, I have changed it. Not sure how it got changed, but it’s back where it should be now.
