Ich verwende derzeit die Testversion, bin also ganz neu und kenn mich noch nicht so aus.
Jetzt wollte ich mein ersten Versuch starten und bekomme die Meldung “Der schnitt ist Möglicherweise außerhalb der Grenzen”
Was hab ich falsch gemacht?
Danke!
I’m currently using the trial version, so I’m new and don’t know much about it yet.
Now I’m trying to make my first attempt and I get the message “The cut may be out of bounds.”
What did I do wrong?
Thanks!
What it says is that your design is not within the working area of your laser.
- It is too large.
- Too much overscan.
- You are not using Absolute Coords, so your start point is too close to one edge.
I believe your machine has limit switches, so it should Home when powered up. By using Absolute Coords, your Lightburn work area and the laser workspace will be the same.
Learn to use the Preview mode. I will show you a lot of the errors you might have.
And have fun!
