I’m having trouble getting Lightburn to correctly control my new Neje Master 2S Max. When I change the machine settings to get “Y” movements correct, the homing procedure goes to the wrong end. If I get the homing correct, the “Y” movement is backwards. Can anyone with this exact Neje model share their configuration or point me to what changes will work for both homing AND “Y” movements? Thanks!
Neje default configuration should work without change in LB. Do you have a backup of the original configuration that you can recover to?
Can you describe in detail what the original problem was that you were trying to resolve that prompted you to make changes?
Right…the default resulted in reversed “Y” movement. When I inverted the “Y” direction in “Machine Settings” that was fixed, but then the homing was backwards. So, I reset the “Y” direction to get the homing to work, but the “Y” direction is backwards. At that point I decided to look for help here.
Can you send a screenshot of your Edit->Device Settings window?
I started over taking the default values and things seem to be working properly now. Thanks!
Make a backup of your settings via the ‘Edit → Machine Settings’… while it’s working…
