What folders or files need to be copied to a different computer in order for the new installation to be identical to the old? Is there a config file that contains any software/device/machine settings?
If you do a File/Open Prefs Folder, that will open the folder. There is a file called prefs.ini in there that stores all the settings for the LightBurn configuration.
Steve is correct - all settings, with the exception of your material library, are stored in the prefs.ini file that will show when you open the prefs folder.
Be sure to close LightBurn before copying it or overwriting it on a new machine, as it’s written over on save.
