I have a file in Lightburn that is showing on the screen correctly.
However when I cut it it mirrors the design.
I have a Ruida controller.
I am sure I need to modify a setting but I don’t know which one. It also shows it backwards on the laser screen.
I have a Perfect Laser 13090
You could try to change the direction of the x- or y-axis.
Can you provide more information ?
Screenshots would help.
The correct answer is that you have your machine origin configured incorrectly in LightBurn. The machine origin is the corner that your laser seeks to when you power it up. This can be corrected in Edit/Device Settings.
