Hi
Since a few days, Lightburn switches off the positioning laser on my iKier K1 when I run framing. I believe this has been since 1.4.04 release. Was there any change or do you have any idea how to fix this?
reverted back to 1.4.03 and positioning laser during framing is on again
Tried 1.4.05 and positioning laser is off again during framing
Try this please:
- Enable Show All in Console
- Run a frame operation
- Capture all output in Console and copy/paste into a reply here.
- Repeat this for both 1.4.03 and 1.4.05.
Also, can you confirm that this is for the crosshairs or the primary laser? LightBurn plays no role in directly controlling the crosshairs.
I have no idea what happened but I uninstalled .3 and installed .5 and now it works, I created a new project and created a simple frame, logs is the same, both fire M3 which uses the positioning crosshair laser while normal framing.
Maybe one of my existing projects which I used to test was broken somehow, no idea.
Thanks for your help and sorry for the confusion
