Lightburn software doesnt start
Hello,
So I was working on lightburn and everything was fine. Then I did the most recent windows 10 updates and right after that lightburn wont open again. It keeps staying on this loading screen.
Any ideas on how to fix it?
Thanks!
I would
a) full restart, retry launching
b) reinstall from installer
c) if it does not open, launch task manager and see if there are multiple lightburn.exe processes running.
Thank you for the suggestions.
I did all of this.
I reinstalled as administrator and did a full virus scan.
Still nothing.any other suggestions?
Hello,
just in case someone else runs into this issue. for me, it helped to start Windows in safe mode. then lightburn started as well and also worked normally again in normal mode.
That tells me there’s a conflict in new update.
Did you try starting in normal mode with Windows and relaunching LightBurn after you got it to run in Safe Mode?
Not sure how savvy you are with Windows but using msconfig to turn off/on startup programs a few at a time might help you determine which one is the culprit.
