i built a mpcnc with an open cnc shield that runs with an Arduino Nano and GRBL1.1h on it.
My problem is, that lightburn stops during the project without a fault.
Sometimes the laser stays on depending of it current job.
It happens after seconds, minutes or 90% job done.
The console hold on the gcode or says
o
k
o
o
k
k
I used the search an tried following:
decrease speed and acceleration
set transfer mode to synchronous
reinstalled ch340-driver
reinstalled lighburn
tried another cable
Also what i noticed, if i step too fast, it freezes in “busy” until i stop it.
Im not sure if the problem is my controller, the driver or something else…
Thanks in advance, sry for my english and greetings
In the Console window in LightBurn there’s a switch on the right that offers ‘Show All’
Some CNC devices offer fairly elaborate reporting. While great for live position tracking with slower machining operations it can be a bit of a load for a Nano with a laser. The GRBL gnea project sets the default for reporting to a minimum.
Do you have the Machine Settings you selected for your build?
The 8 none and 1 at the top might be a popular choice.
The $10 setting may be of interest.
There’s a slim chance that the high current Power Supply for the drive motors is injecting noise into the serial communication. It may be worth testing the CNC controller with USB serial power only to verify that it communicates easily.
Looking forward to knowing more about your setup. You’re welcome to post Pics here by dragging them into the compose / reply / edit box.
