The top toolbar on Lightburn has moved and now covers the dropdown menus. It appears to have completely detached its self from the main window and I have not been able to restore it to normal.
If the whole window is moved usinf the right mouse button the toolbar remains where it is. I have tried reinstalling the program but it is still the same. This is on my laptop used to control the laser. The Lightburn installation on my desktop is OK. Both running Widows10. Lightburn 1.5.01 Any help would be appreciated.
I have attached a screen shot.
There is no screenshot ![]()
Try Window → Reset do default layout
If you can’t see the menu bar, press ALT+W and then enter key. Should work the same.
Grab the 3 dots on the left side of the toolbar and drag it back into position. The cursor should change to a cross when you hover over them.
Many thanks for the quick reply.
Problem solved..
Still a mystery what upset it in the first place.
Working fine one day and boot up next time and fault present.
Mouse on steroids?
Ghosts, I recon.
