Hi there, subject mostly tells you what I’m running into. New to LightBurn and trying to get it set up with my Neje Master 2S Plus.
Running LightBurn on my MBP, it will not import from an lbset file.
I’ve managed to install LightBurn on my ancient Windows 7 netbook, and it’s unusably slow overall, but it will import from the same lbset file without a problem.
Am I missing something obvious here? Is this a known issue? Can I assume I’m doing something wrong?
Do they not appear in the dialog when trying to open?
Do they appear but not allow you to select them?
Do they let you select, but then just not open?
Be as specific as you can - I haven’t heard of this issue before.
One thing that might be the issue - Windows is not case sensitive with filenames, but MacOS is. If the files were saved with upper-case extensions instead of lower case, that could case problems on the Mac.
I can see the files in the dialog when trying to open them, but cannot select them. They are greyed out.
I’ve checked the file extension, and it’s all lowercase. Just in case, I’ve also gone into the file info and selected LightBurn as the application that should open these files, but that hasn’t made any difference.
Just now, I double-clicked on the files to see what happened, and I got the message:
LightBurn doesn’t recognize the extension lbdev in filename: /blah/blah/blah/NejeMaster2DeviceProfile.lbdev
Same sort of message for the lbset file I’ve got. So it seems like it might have something to do with the file extension?
I was trying to import them, in the manner you described. As noted before, the same files imported no problem on the Windows machine. Trying to do the same thing in the same way in MacOS, can’t select the files (greyed out).
