LightBurn v2.0.05 RC7 Release Candidate
The seventh release candidate for LightBurn v2.0.05 is now available to download here:
LightBurn-v2.0.05-RC-7 - Change Log
Changes Since LightBurn-v2.0.05-RC-6
Bug Fixes
  • Fixed issue causing toolbar icons to double in size when a dialog is on a different screen to the main window.
  • Fixed bug that can occasionally set all console text to the color red.
User Interface Updates
  • Console colors are now set from the application theme.
Other Changes Since LightBurn-v2.0.04
Bug Fixes
  • Rotary jogging was flipping directions in CCW direction for rotary and XY controls.
  • Units could get corrupted for galvo devices
  • Emblaser WiFi wizard dark mode issues on Windows due to Aero theme (#1253)
  • Material library combo box was too wide (#1254)
  • Deform on an image could glitch on parallel lines (#1262)
  • Importing SVG with ungrouped DEF shapes could crash (#1278)
  • Fixed issue with device settings incorrectly sizing custom gcode options tab contents.
  • Art library crashed if files dropped when no library selected (#1338)
  • Auto-join could crash in extremely rare cases from a float rounding issue (#1335)
  • Tab drawing wasn’t saving/restoring drawing color (#1345)
  • Double-click to launch if unconfigured would crash (#1272)
  • Trim would fail if snipping a shape scaled to zero in X or Y (#1383)
  • Set Zero on BSL could hang the hardware (#1378)
  • Hide other bundle controls when editing vendor info (#1248)
  • Added higher resolution images for unidirectional and offset fill types.
  • Prevent app title bar from appearing off screen when stored window position offsets are incorrect.
New Features
  • Added toggle switch to disable KT332N U → Z axis mapping (#1310)
Existing Feature Updates
  • Galvo framing now gracefully handles when you have too many shapes (#1321)
  • Increased galvo rotary size limits to 20 meters
  • Updated rotary runner screen limits to match setup screen
  • Shrink the cut settings window (#1276)
  • Smaller galvo settings window for Devil’s Resolution (#1288)
  • Reduced cut setting window 10 pixels more by reducing the dither preview size (#1291)
  • Remove the null at the end of Adobe’s SVG paste data (#1373)
