Lightburn version to use
what version of Lightburn i need to porches for my Atomstack A10 pro?
Atomstack would require g-code version. DSP version would also work as it includes g-code ability if for some reason you have a need for DSP.
Thank you for reaching out, and as @berainlb identifies, you will need the GCode version to support your Atomstack laser. We recommend you try our trial version first to insure LightBurn is the right choice for your needs. Download & Trial - Try before you buy – LightBurn Software. :slight_smile:
And this should assist you in getting things setup correctly, and understanding the basics of using LightBurn: Home - LightBurn Software Documentation
