Lightburn visual changes
Since my last upgrade to 1.7.06 I’m having a difficult time seeing parts of the screen like adjusting width and height of my project. That area seems ghosted out compared to the rest of screen. The area that shows the lock and you pick mm verses inches area. The rest of the screen seems darker was there a change here if so how do I darken it to see it better. I have tried adjusting settings but that section stays the same ?
Respectfully,
It depends on whether an object in the workspace is selected.
Light gray means “nothing selected”:
Dark(er) gray means “something selected”:
In either case, numeric field widths do not track the character size, so numbers lose their most significant digits without warning. Alas, reducing the character size to fit the fixed-width fields bumps against my readability limits.
Modern UI design seems created by and intended for twenty-something males with perfect vision.
Or bigger screens.
I deployed a 2560×1440 display a while ago and it’s already fallen off the trailing edge of the progress wedge.
Living in the future is great, but I’m pedaling as fast as I can! :biking_man:
The gray stays the same while making changes which is why I posted this comment its hard to read for some reason while being selected ?
If it doesn’t change when nothing is selected in the workspace (click the workspace outside all the objects), then this could be an interaction with the Microsoft Surface UI.
A pair of screenshots with nothing selected and one object selected will let us see what you see.
With those, @JohnJohn will know how to proceed.
