Lightburn vs Snapmaker Artisan 40W Laser schneidet nur eine Form aus
Eine SVG Datei kann mittels Lightburn an den Snapmaker Artisan 40W gesendet werden. Der The laser starts as desired and begins cutting. After the first shape, the laser beam switches off. However, the device continues to run through the entire job. Only the laser no longer switches on.
What am I overlooking?
Can you upload the file?
I’ve tried many different shapes. None of them work.
Only one pattern is cut out.
Hallo Christian,
Das ist ein bekanntes Problem mit dem Artisan, das aber einfach gelöst werden kann.
Wir haben Snapmaker informiert, aber offenbar haben sie die Anleitung noch nicht angepasst.
One of your shared customers with an Artisan 3in1 40W contacted us with a problem, where only the first shape was lasered.
We found a solution by enabling “Emit S value with every G1 command” in the Device Settings in LightBurn:
We wanted to inform you about this because the .LBDEV files on this instructions page are missing this bit:
Using Ray/Artisan/2.0 with LightBurn | Snapmaker Wiki
We have attached a .zip file containing all your Device Profiles with the added setting to make it easy to replace the files.
snapmaker-artisan-40w-v1(4).lbdev (5.1 KB)
Hallo Aaron,
Vielen Dank, das hat nun geholfen.
Ich kann nun richtig loslegen. :slight_smile:
