LightBurn WebTools – What if you could send selected artwork directly to a web application?
If you’ve ever used an online SVG editing or processing tool alongside LightBurn, you’ll probably be familiar with the routine.
First, you select your artwork in LightBurn and export it as an SVG file. Then you open the web-based tool, find its import option, locate the SVG file you just saved, and upload it.
Once you’ve finished working on the artwork, you download the modified SVG back into LightBurn.
It works, but it’s a rather cumbersome process, particularly if you’re making frequent changes or experimenting with different tools.
What if you could eliminate most of those steps?
I’ve been experimenting with a small Windows application that acts as a bridge between LightBurn and compatible web-based tools.
The bridge makes LightBurn’s copied vector data available to web applications, allowing them to read the artwork directly without having to export an intermediate SVG file.
How the new workflow works
  1. Select the artwork you want to work with in LightBurn.
  2. Copy the selected objects.
  3. Open a compatible web application through LightBurn’s WebTools feature.
  4. The web application automatically reads the artwork through the bridge and displays it, ready for editing or processing.
  5. When finished, the web application can send the resulting artwork back to LightBurn using its existing import capabilities.
No intermediate SVG files to save, locate or upload.
The interesting thing is that the bridge isn’t tied to any particular web application. Any suitably developed web tool could potentially use it to receive selected LightBurn artwork.
This could be useful for specialist vector editors, design utilities, geometry processing tools, or other applications that complement LightBurn without needing to be built into LightBurn itself.
There are some limitations, particularly with certain native LightBurn objects that may need converting to paths, but the basic concept is working.
LightBurn already provides ways for external applications to send artwork into it. This bridge adds the missing part of the workflow by making selected LightBurn artwork accessible to compatible web tools.
I think this opens up some interesting possibilities for developers using LightBurn’s WebTools feature.
Has anyone else experimented with this sort of integration, or can you think of other web-based tools that could benefit from it?
Video of the tool working: Lightburn send svg to Web Tools. sorry about the poor quaility, my youtube skills are very limited.
I believe we’re already working on doing this natively
Even better.
