Part of the github page should have been about identifying existing drivers as to remove potential conflicts. Did you do that?
I do not see anywhere in the GitHub page you sent where it explains finding and removing conflicts. There is a note at the bottom of the page that talks about uninstalling the driver but I think that is talking about the driver they just walked the user through to install. Where is this information you are talking about?
You’re right. They don’t talk specifically about resolving driver conflict on that page and the uninstall instructions there are incomplete. I believe I was remembering a different page I can’t seem to find now.
Check out these resources. They touch on this a bit. Part of the challenge is that MacOS has changed the driver model and installation location of these things multiple times in the last few years which makes it hard to find the right information.
GitHub - adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver: CH340G CH34G CH34X Mac OS X driver
Troubleshooting CH340G issues on macOS - FAQ - PlatformIO Community
Ok so I should try the install instructions on this page where it asks to remove drivers and do another install. Is that correct?
Yes. But I’d suggest documenting everything that you find so that you have a record of what was done. That will provide insight into what the actual problem is.
Steps followed from GitHub (note: computer name replaced with xxxxxx in notes below)
Step 2
- sudo kextunload /Library/Extensions/usbserial.kext
xxxxxxxx@MacBook-Pro ~ % sudo kextunload /Library/Extensions/usbserial.kext
Password:
Executing: /usr/bin/kmutil unload -p /Library/Extensions/usbserial.kext
Error Domain=KMErrorDomain Code=71 “Could not find: No bundle was found at /Library/Extensions/usbserial.kext.” UserInfo={NSLocalizedDescription=Could not find: No bundle was found at /Library/Extensions/usbserial.kext.}
xxxxxxxxxxxx@MacBook-Pro ~ %
- sudo kextunload /System/Library/Extensions/usb.kext
xxxxxxxxxxxx@MacBook-Pro ~ % sudo kextunload /System/Library/Extensions/usb.kext
Executing: /usr/bin/kmutil unload -p /System/Library/Extensions/usb.kext
Error Domain=KMErrorDomain Code=71 “Could not find: No bundle was found at /System/Library/Extensions/usb.kext.” UserInfo={NSLocalizedDescription=Could not find: No bundle was found at /System/Library/Extensions/usb.kext.}
Step 3
- sudo rm -rf /System/Library/Extensions/usb.kext
xxxxxxxxxxxx@MacBook-Pro ~ % sudo rm -rf /System/Library/Extensions/usb.kext
- sudo rm -rf /Library/Extensions/usbserial.kext
xxxxxxxxxxxx@MacBook-Pro ~ % sudo rm -rf /Library/Extensions/usbserial.kext
Step 4
Downloaded CH341SER_MAC.ZIP
Installed using the .dmg
Drag app to folder
Replaced existing
Opened driver and installed
Install success
Step 6
xxxxxxxxxxxx@MacBook-Pro ~ % sudo kextload /Library/Extensions/usbserial.kext
Executing: /usr/bin/kmutil load -p /Library/Extensions/usbserial.kext
Error Domain=NSPOSIXErrorDomain Code=2 “No such file or directory”
Stopped remaining as there was no sense plugging in the tool if it still was an error in last command.
First validate whether or not the files that you are attempting to remove exist. What’s the current state of the USB driver. Is it still getting loaded and visible in System Report?
If you’ve removed everything nothing should show there.
If you’re getting that in System Report that means you haven’t removed all drivers.
I forget the correct command but there’s a way to show loaded kext files. Try to identify what driver is being loaded and where it’s located in the filesystem.
Ran command:
xxxxxx@MacBook-Pro ~ % kextstat | grep -v com.apple
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
Index Refs Address Size Wired Name (Version) UUID
I then ran a full kextstat command. Looks like a have a ton.
xxxxxxxx@MacBook-Pro ~ % kextstat
1 119 0 0 0 com.apple.kpi.bsd (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
2 12 0 0 0 com.apple.kpi.dsep (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
3 161 0 0 0 com.apple.kpi.iokit (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
4 0 0 0 0 com.apple.kpi.kasan (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
5 0 0 0 0 com.apple.kpi.kcov (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
6 166 0 0 0 com.apple.kpi.libkern (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
7 147 0 0 0 com.apple.kpi.mach (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
8 115 0 0 0 com.apple.kpi.private (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
9 101 0 0 0 com.apple.kpi.unsupported (22.6.0) F75FC53F-FC1A-3AB6-8980-EF66A83DD51D <>
10 14 0xffffff80036db000 0x78fd0 0x78fd0 com.apple.kec.corecrypto (12.0) 9007FC53-5A05-30FE-9EF0-710A59D4AA69 <9 8 7 6 3 1>
11 0 0xffffff8001846000 0x3000 0x3000 com.apple.kec.AppleEncryptedArchive (1) 41E94CC9-452A-30AF-98C0-776ABE3E16FF <10 8 7 6>
12 0 0xffffff8001d67000 0x1ffd 0x1ffd com.apple.kec.Compression (1) 591784ED-D6FB-3C9C-A092-08891081AD11 <10 8 7 6>
13 2 0xffffff8003463000 0xdfe0 0xdfe0 com.apple.kec.Libm (1) E83D62EF-41CE-3A9D-B71D-07861FF8FB86 <6>
14 0 0xffffff800377d000 0x7000 0x7000 com.apple.kec.pthread (1) 183E2FDA-EF4D-3EFE-B98C-0BC477186E17 <9 8 7 6 3 1>
15 1 0xffffff8003793000 0x2fff 0x2fff com.apple.driver.watchdog (1) BD08CE2D-77F5-358C-8F0D-A570540A0BE7 <9 8 7 6 3 1>
16 32 0xffffff8002a3c000 0x2000 0x2000 com.apple.iokit.IOACPIFamily (1.4) D342E754-A422-3F44-BFFB-DEE93F6723BC <9 8 6 3>
17 36 0xffffff8002eac000 0x32000 0x32000 com.apple.iokit.IOPCIFamily (2.9) F11A1D9C-398D-3933-94D6-9539D3B7B1FD <9 8 7 6 3>
18 13 0xffffff8001ade000 0x1d000 0x1d000 com.apple.driver.AppleSMC (3.1.9) DD55DA6A-679A-3797-947C-0B50B7B5B659 <17 16 15 9 8 7 6 3 1>
19 2 0xffffff8001369000 0x77ff1 0x77ff1 com.apple.driver.AppleACPIPlatform (6.1) 079C50B9-FCFD-3C4C-8BC4-3CF9DD26F27A <18 17 16 9 8 7 6 3 1>
20 6 0xffffff8002fd6000 0x1fff 0x1fff com.apple.driver.IOSlaveProcessor (1) AE814FB3-F7DE-39F0-BB01-08669928B892 <8 7 6 3>
21 4 0xffffff8001ac4000 0xdffc 0xdffc com.apple.driver.AppleSEPManager (1.0.1) 3ACE0D43-F415-3D1B-AF6C-0BB1CC4CBF3F <20 17 10 9 8 7 6 3 1>
22 1 0xffffff800172a000 0x4000 0x4000 com.apple.driver.AppleBusPowerController (1.0) 95C644D4-B16C-3595-96B0-68A902F73C39 <18 16 8 7 6 3>
23 6 0xffffff8001c67000 0x3ffc 0x3ffc com.apple.driver.usb.AppleUSBCommon (1.0) 02C83172-34E4-3CD4-9086-24FCEA2E81B3 <7 6 3 1>
24 1 0xffffff8003329000 0xfff 0xfff com.apple.driver.AppleUSBHostMergeProperties (1.2) D850B2B9-619A-3DE5-A545-1AFF90B3D0EF <6 3 1>
25 10 0xffffff8003252000 0x75ff4 0x75ff4 com.apple.iokit.IOUSBHostFamily (1.2) D0E25720-2CF2-31CE-A1B5-BD0CEC23EF95 <24 23 22 18 16 9 8 7 6 3 1>
26 3 0xffffff800344b000 0xefff 0xefff com.apple.driver.KernelRelayHost (1) 833E0F51-A8CB-3634-8F47-E18BFC0B4633 <25 7 6 3>
27 6 0xffffff8001d6a000 0x9ff7 0x9ff7 com.apple.iokit.CoreAnalyticsFamily (1) E4FBE84B-1C41-39A0-9371-312F65D85A60 <9 8 7 6 3 1>
28 1 0xffffff80017a0000 0x6fffc 0x6fffc com.apple.driver.AppleCredentialManager (1.0) 790A6A7D-30AC-35AE-BBC6-49BFA38DF6B7 <27 26 21 20 10 9 8 7 6 3 1>
29 4 0xffffff8001e48000 0x9ffa 0x9ffa com.apple.kext.CoreTrust (1) 26269D36-526F-3B92-9637-28879F276FA4 <10 8 6>
30 2 0xffffff80018c4000 0x1eff6 0x1eff6 com.apple.security.AppleImage4 (5.0.0) E55B53C4-C3DF-3B13-83C8-28361E9F756F <29 10 9 8 7 6 3 2 1>
31 9 0xffffff80019fd000 0x33ffa 0x33ffa com.apple.driver.AppleMobileFileIntegrity (1.0.5) 113550EC-8AB4-3E71-A39B-4C9E4FD16720 <30 29 27 10 9 8 7 6 3 2 1>
32 0 0xffffff800181a000 0x2ff8 0x2ff8 com.apple.driver.AppleCyrus (1) B1F4EA58-E941-3031-BD3A-CE7B43C7FF50 <31 29 21 20 9 8 7 6 3 1>
33 2 0xffffff800183a000 0x6000 0x6000 com.apple.driver.AppleEffaceableStorage (1.0) C3440029-A77E-3694-9EF3-FF91C5473291 <9 7 6 3 1>
34 0 0xffffff800184a000 0x6000 0x6000 com.apple.driver.AppleFDEKeyStore (28.30) F8B72019-7931-31F6-89BC-56164924FF5C <33 10 9 8 7 6 3 1>
35 3 0xffffff8002ef4000 0x15000 0x15000 com.apple.iokit.IOSCSIArchitectureModelFamily (482.120.2) 4B9D881E-8C59-33BA-BCE2-18029B6444EA <8 7 6 3 1>
36 10 0xffffff8002fe1000 0x18000 0x18000 com.apple.iokit.IOStorageFamily (2.1) 70B6B0B8-8059-3529-A544-D33C65534409 <9 8 7 6 3 1>
37 1 0xffffff8002f1c000 0x10fff 0x10fff com.apple.iokit.IOSCSIBlockCommandsDevice (482.120.2) C2D2C000-791E-3078-9541-F6C01340409E <36 35 8 7 6 3 1>
38 1 0xffffff8003425000 0x1b000 0x1b000 com.apple.iokit.IOUSBMassStorageDriver (235.140.2) 25D75F47-2ABC-37FA-ACA1-7F7F4D377BEB <36 35 25 17 8 7 6 3 1>
39 1 0xffffff8001b52000 0x7ffd 0x7ffd com.apple.driver.AppleUSBTDM (554) 42E56A3A-AE91-3326-9CB2-4D45EE71EF0D <38 37 36 35 31 25 9 8 7 6 3 1>
40 0 0xffffff8001943000 0x8bffd 0x8bffd com.apple.driver.AppleKeyStore (2) 448BF957-BADB-33AA-8FFC-EFB0E1D830E9 <39 31 29 28 26 21 20 10 9 8 7 6 3 1>
41 0 0xffffff8001b05000 0x9000 0x9000 com.apple.driver.AppleSSE (1.0) 85D06AEC-810B-3639-B561-EC24284757CF <26 21 20 9 8 7 6 3 1>
42 0 0xffffff8001e54000 0x2ff8 0x2ff8 com.apple.Dont_Steal_Mac_OS_X (7.0.0) 5E7E5641-2CDD-33E7-93DE-A37D162AECC2 <18 10 9 8 6 3 1>
43 2 0xffffff80019f8000 0x3000 0x3000 com.apple.kext.AppleMatch (1.0.0d1) AD200C9A-8E7A-3636-877C-4C5A4CA3EE73 <8 6 3 1>
44 3 0xffffff8003498000 0x52000 0x52000 com.apple.security.sandbox (300.0) FAF9E505-E0F0-343F-B230-2AF3E4230AF4 <43 36 31 9 8 7 6 3 2 1>
45 2 0xffffff800348d000 0x9ff1 0x9ff1 com.apple.security.quarantine (4) 1836ECA8-5D9F-3C14-9BAE-8569E772D20E <44 43 9 8 7 6 3 2 1>
46 0 0xffffff8001e5a000 0x5ffff 0x5ffff com.apple.iokit.EndpointSecurity (1) E15A9CB6-EE30-32B6-B1D9-4B9377CB7649 <45 31 9 8 7 6 3 2 1>
47 9 0xffffff8002eee000 0x2ff8 0x2ff8 com.apple.iokit.IOReportFamily (47) 491DDA55-D371-3A28-9A77-C28DB013D8AE <8 7 6 3>
48 2 0xffffff8002ab0000 0x37000 0x37000 com.apple.iokit.IOBluetoothFamily (9.0.0) 0015A8D2-7307-3770-AB5C-36884F2482E3 <47 25 16 9 8 7 6 3 1>
49 0 0xffffff8002b2c000 0xc000 0xc000 com.apple.driver.DiskImages (493.0.0) 837CD79A-C46F-317A-B95A-A445DFDDB126 <36 9 8 7 6 3 1>
50 0 0xffffff8002c11000 0xfff 0xfff com.apple.iokit.IOKitRegistryCompatibility (1) 4C5D2489-50F1-3E93-9C59-582AA5F01326 <6 3>
51 10 0xffffff8002c4b000 0x16ff4 0x16ff4 com.apple.iokit.IONetworkingFamily (3.4) 905F3FAB-0203-37DA-B537-7F8507149A78 <9 8 7 6 3 1>
52 2 0xffffff8002ea5000 0x5000 0x5000 com.apple.driver.mDNSOffloadUserClient (1.0.1b8) BA6FE987-65DB-34CE-AAA0-CEBB09C55B21 <51 8 6 3 1>
53 6 0xffffff8002f98000 0x2d000 0x2d000 com.apple.iokit.IOSkywalkFamily (1.0) 035A9AD9-6CDE-362F-8DEC-B664BC6431EC <52 51 9 8 7 6 3 1>
54 2 0xffffff8003163000 0x2dff8 0x2dff8 com.apple.iokit.IOTimeSyncFamily (1150.2) 9CDD7660-4115-357A-96AC-59994E39181F <53 51 8 7 6 3 1>
55 0 0xffffff8001360000 0x7ff4 0x7ff4 com.apple.nke.applicationfirewall (404) 7BF296CC-746B-3312-BF4A-F8A3650828A9 <9 8 7 6 3 1>
56 0 0xffffff8001b7c000 0xefff 0xefff com.apple.AppleSystemPolicy (2.0.0) FB61269C-7F00-30E4-9CD7-B920617D27BE <45 44 31 9 8 7 6 3 2 1>
57 0 0xffffff8001cb7000 0xff8 0xff8 com.apple.security.AppleUserConsent (1) 38011687-F238-3D61-A202-0B07C4A01723 <9 8 7 6 2 1>
58 0 0xffffff8001426000 0x2000 0x2000 com.apple.driver.AppleAPIC (1.7) 99F0CD8C-3575-320A-AB46-89D03642C5BA <17 6 3>
59 12 0xffffff8002b77000 0x62000 0x62000 com.apple.iokit.IOHIDFamily (2.0.0) C5F0129A-C819-3C42-9DCA-531454F9CDDF <47 9 8 7 6 3 2 1>
60 3 0xffffff8002f83000 0xffe 0xffe com.apple.iokit.IOSMBusFamily (1.1) 02901024-7468-311C-98A7-896350D03A80 <7 6 3>
61 0 0xffffff80013f7000 0x6000 0x6000 com.apple.driver.AppleACPIEC (6.1) EF61E26B-21D1-3FAB-891A-34F8B90EC5C3 <60 59 47 19 16 9 8 7 6 3 1>
62 0 0xffffff8001ad9000 0x2ffe 0x2ffe com.apple.driver.AppleSMBIOS (2.1) 0610E081-A6CB-3381-89C8-3041A2C2BB90 <9 6 3>
63 0 0xffffff8001a9d000 0x5ff4 0x5ff4 com.apple.driver.AppleRTC (2.0.1) 5B7DB50D-D132-3806-BA66-482836486310 <16 9 7 6 3 1>
64 2 0xffffff8001820000 0x2000 0x2000 com.apple.driver.AppleEFIRuntime (2.1) CBE99540-C4C5-348D-9154-5A5CF8AA646A <27 9 8 7 6 3>
65 0 0xffffff8001b11000 0x18ff4 0x18ff4 com.apple.driver.AppleSmartBatteryManager (161.0.0) 65B2F9C5-0625-37DD-9596-6F160E87D00D <60 18 16 8 7 6 3 1>
66 0 0xffffff80013f0000 0x2ffa 0x2ffa com.apple.driver.AppleACPIButtons (6.1) 649A8E15-7037-3F58-84DA-047BE0841CB0 <59 47 19 16 9 8 7 6 3 1>
67 2 0xffffff8001824000 0xa000 0xa000 com.apple.driver.AppleEFINVRAM (2.1) F8DA24BC-B401-36FF-8ED1-2BABE80EA0C5 <64 9 8 7 6 3 1>
68 1 0xffffff8003379000 0x3cff8 0x3cff8 com.apple.driver.usb.AppleUSBXHCI (1.2) DE9A5356-0DB4-3CA4-96A4-F7E66865DD16 <25 23 16 9 8 7 6 3 1>
69 0 0xffffff80033c0000 0x24ff5 0x24ff5 com.apple.driver.usb.AppleUSBXHCIPCI (1.2) 73AF9981-98B1-339F-826D-805EA2D4A409 <68 25 23 17 16 9 8 7 6 3 1>
70 1 0xffffff800190c000 0x7000 0x7000 com.apple.driver.AppleIntelLpssGspi (3.0.60) 810EF4EB-90D7-3579-82FF-8C533059D92C <17 16 9 7 6 3>
71 1 0xffffff8001915000 0x6ff4 0x6ff4 com.apple.driver.AppleIntelLpssI2C (3.0.60) 63C1D555-693D-3101-94E8-CD0E38299F73 <17 16 9 7 6 3>
72 0 0xffffff800345f000 0x1000 0x1000 com.apple.private.KextAudit (1.0) 905AC4E7-AB0F-3043-A945-DDB283895D9F <18 9 8 7 6 3>
73 0 0xffffff80031a5000 0x63ff5 0x63ff5 com.apple.iokit.IOUSBFamily (900.4.2) F7F1C2A0-5EA5-3741-A183-73CECD769D50 <25 23 17 9 7 6 3 1>
74 0 0xffffff800332c000 0x2ff5 0x2ff5 com.apple.driver.usb.AppleUSBHostPacketFilter (1.0) 04A6BA69-CD17-3D20-A9F0-2BB9F3ED7078 <25 23 9 8 7 6 3 1>
75 2 0xffffff8001905000 0x5000 0x5000 com.apple.driver.AppleIntelLpssDmac (3.0.60) 84330AB1-A6B2-3849-A951-41F09295BF0C <17 16 7 6 3>
76 1 0xffffff8001932000 0xd000 0xd000 com.apple.driver.AppleIntelLpssSpiController (3.0.60) 9211E950-A577-3476-93BC-ED751BFBA486 <75 70 16 7 6 3>
77 0 0xffffff8002c14000 0x2d000 0x2d000 com.apple.iokit.IONVMeFamily (2.1.0) D6B20D06-8D30-36EF-930A-378AFC969811 <47 36 31 17 9 8 7 6 3 1>
78 2 0xffffff80036aa000 0x22ff5 0x22ff5 com.apple.driver.corecapture (1.0.4) 9E59BABB-614E-3F00-AAF5-99AD06E2DA50 <9 8 7 6 3 1>
79 1 0xffffff80020eb000 0x146ffd 0x146ffd com.apple.iokit.IO80211FamilyLegacy (1200.12.2b1) A5867D1C-0C33-3FFE-BDE8-AEA39EE38AAD <78 53 51 31 27 10 9 8 7 6 3 1>
80 0 0xffffff800224d000 0x558ffe 0x558ffe com.apple.driver.AirPort.BrcmNIC (1400.1.1) 39471941-4FEB-341D-8F9B-F28AF5F18AFA <79 78 53 52 51 17 9 8 7 6 3 1>
81 1 0xffffff80018a9000 0xe000 0xe000 com.apple.driver.AppleHSSPISupport (63) EBCFF06F-016F-39ED-8B0E-F31E2275C04C <76 16 8 7 6 3 1>
82 7 0xffffff8003042000 0xf3000 0xf3000 com.apple.iokit.IOThunderboltFamily (9.3.3) 3E47A595-6563-3D9F-BB45-848767960189 <18 7 6 3 1>
83 0 0xffffff8001bdb000 0x30fff 0x30fff com.apple.driver.AppleThunderboltNHI (7.2.81) 5C87D72F-BC15-39B4-8CCF-F832F98A0BAB <82 17 16 8 7 6 3 1>
84 0 0xffffff80018a1000 0x5000 0x5000 com.apple.driver.AppleHSSPIHIDDriver (63) BBA5DAEE-8572-3BC6-9D97-AB90E66763CD <81 59 8 7 6 3 1>
85 1 0xffffff8002af1000 0x13ffa 0x13ffa com.apple.driver.IOBluetoothHIDDriver (9.0.0) 6D5EDFA8-C8DE-3DF4-89CB-58073D456C62 <59 48 7 6 3>
86 1 0xffffff8001c46000 0x6ff1 0x6ff1 com.apple.driver.AppleHSBluetoothDriver (6440.7) 58577F8E-C877-3B38-BCDB-5E3E419CEA0A <85 59 48 8 7 6 3 1>
87 2 0xffffff80018ef000 0xeffd 0xeffd com.apple.driver.AppleInputDeviceSupport (6460.1) AB3CA1D0-6703-3C20-8D41-286EC992F8EE <27 20 7 6 3 1>
88 2 0xffffff8001a44000 0x14ff9 0x14ff9 com.apple.driver.AppleMultitouchDriver (6440.7) CC2AEE9A-C4C2-302D-B543-EACA0E343525 <87 59 47 9 8 7 6 3 1>
89 0 0xffffff8001c51000 0x8ff3 0x8ff3 com.apple.driver.AppleTopCaseHIDEventDriver (6440.7) 8175382D-21E7-391B-B629-0D6A988A4361 <88 86 59 8 7 6 3 1>
90 0 0xffffff8001877000 0x4ff4 0x4ff4 com.apple.driver.AppleHIDKeyboard (231) 52D9DE24-79A1-3DFA-9F1F-6E7402228B2B <59 8 7 6 3>
91 0 0xffffff800142a000 0x7ffb 0x7ffb com.apple.driver.AppleActuatorDriver (6440.7) 7C3839C5-11B7-3F60-8506-AF60FE4B32E6 <88 87 59 47 9 8 7 6 3 1>
92 0 0xffffff8001853000 0x2000 0x2000 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) 22E0112D-B601-3F66-B219-E76ED0AFD777 <9 8 6 3 2 1>
93 0 0xffffff8001857000 0x11fea 0x11fea com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0) 46A260EF-D391-33D8-AF94-2E0F91EC0D28 <8 6 3 2 1>
94 0 0xffffff8001b74000 0x3ff9 0x3ff9 com.apple.driver.AppleSyntheticGameController (10.7.1) D8CFD354-5277-37F8-8223-894F02E4F769 <59 8 6 3>
95 0 0xffffff8001d56000 0xcff4 0xcff4 com.apple.BootCache (40) 5C0E1D04-57A3-3655-97AE-5BF376A20104 <9 8 7 6 3 1>
96 1 0xffffff8001f28000 0x1ff9 0x1ff9 com.apple.filesystems.hfs.encodings.kext (1) 4E24C57C-BE70-3220-A044-9C119CC493EE <9 8 7 6 3 1>
97 0 0xffffff8001ec3000 0x5f000 0x5f000 com.apple.filesystems.hfs.kext (627.100.6) CAF8C690-A929-3860-85FA-53C47058BA02 <96 9 8 7 6 3 1>
98 3 0xffffff8003010000 0x29000 0x29000 com.apple.iokit.IOSurface (336.60.1) CEE7530A-8DE3-30C6-9EE3-EC791D0A2CAC <9 8 7 6 3 1>
99 2 0xffffff8003505000 0x190ff0 0x190ff0 com.apple.filesystems.apfs (2142.140.9) 3D333E85-4C25-3EFF-B8D7-4B089E1C3B5E <67 36 33 30 27 10 9 8 7 6 3 2 1>
100 0 0xffffff8003760000 0x18ffc 0x18ffc com.apple.filesystems.lifs (1) 119008F4-1926-3299-B234-966177D04A25 <9 8 7 6 3 1>
101 0 0xffffff8001700000 0x1000 0x1000 com.apple.driver.AppleBSDKextStarter (3) 95B265DD-DF56-3367-9432-38BB8C9D42A6 <6 3>
102 0 0xffffff8003786000 0xb000 0xb000 com.apple.filesystems.tmpfs (1) FCB8C31A-6277-3D61-B388-049F7ABCC808 <9 8 7 6 3 1>
103 0 0xffffff800186d000 0x2000 0x2000 com.apple.driver.AppleFileSystemDriver (3.0.1) 8DCFE5AC-F56F-3023-B78B-212CFD00125F <36 6 3>
104 0 0xffffff8001cf7000 0x3000 0x3000 com.apple.driver.AppleXsanScheme (3) 048C4497-C021-36B6-9398-16CEAEB66E87 <36 7 6 3 1>
105 1 0xffffff800191e000 0xdffc 0xdffc com.apple.driver.AppleIntelLpssI2CController (3.0.60) 0CD83BE2-C14A-38CC-80E9-BDF6F7956B29 <75 71 16 9 7 6 3>
106 0 0xffffff8001893000 0x7ff6 0x7ff6 com.apple.driver.AppleHPM (3.4.4) DD797183-E977-3EF2-AA32-D341A28446F1 <105 82 16 7 6 3 1>
107 2 0xffffff8001b8f000 0x17000 0x17000 com.apple.driver.AppleThunderboltDPAdapterFamily (8.5.1) 6C31434D-6960-329A-908D-9EB34A3103C4 <82 7 6 3 1>
108 0 0xffffff8001ba9000 0x9fff 0x9fff com.apple.driver.AppleThunderboltDPInAdapter (8.5.1) 2D0304E3-3D96-3FC6-8A16-58FA15259066 <107 82 16 7 6 3 1>
109 0 0xffffff8001c17000 0x3fff 0x3fff com.apple.driver.AppleThunderboltPCIDownAdapter (4.1.1) 3E4A172F-1680-38FC-927B-64951B55F6D3 <82 17 7 6 3 1>
110 4 0xffffff8002f86000 0x7000 0x7000 com.apple.iokit.IOSerialFamily (11) 1C8819AD-328C-3096-A29C-0AE9A6B9396C <9 8 7 6 3 1>
111 0 0xffffff7f9635a000 0x7000 0x7000 com.apple.driver.driverkit.serial (6.0.0) 6D9222B1-CC3A-3AA9-80B8-37DBE7E341CB <110 7 6 3 1>
113 1 0xffffff7f95ded000 0x6ffd 0x6ffd com.apple.driver.AppleSMBusController (1.0.18d1) 18305D5D-1310-37BC-B654-6C034FD346E7 <60 17 16 7 6 3>
114 16 0xffffff7f961c1000 0x2efca 0x2efca com.apple.iokit.IOGraphicsFamily (597) 718E01CF-8B05-3042-88F4-DE3441395D00 <17 9 7 6 3 1>
115 0 0xffffff7f95d90000 0xb000 0xb000 com.apple.driver.AppleMCCSControl (1.16) 3C019431-9987-3A60-867C-DFC5EC1292E5 <114 113 18 17 16 9 7 6 3 1>
117 5 0xffffff7f95104000 0x4000 0x4000 com.apple.AppleGraphicsDeviceControl (7.1.18) B22B74AE-08E9-3D23-8F7A-EAD3C39EE7AD <114 17 9 8 7 6 3 1>
118 2 0xffffff7f96020000 0x6affc 0x6affc com.apple.iokit.IOAcceleratorFamily2 (475.40.6) 5CEA519D-44FC-30EB-8622-2394570EBDD4 <114 98 47 31 17 9 8 7 6 3 1>
119 0 0xffffff7f95b02000 0xc2ff8 0xc2ff8 com.apple.driver.AppleIntelKBLGraphicsFramebuffer (20.0.6) 62C9F293-31A9-356B-932B-880BE5524774 <118 117 114 47 17 16 9 8 7 6 3 1>
120 4 0xffffff7f96215000 0x8ffc 0x8ffc com.apple.iokit.IONDRVSupport (597) 822CC0A2-790D-3CCE-B679-9B920226F533 <114 17 9 7 6 3>
121 0 0xffffff7f95dfc000 0x4000 0x4000 com.apple.driver.AppleSMCLMU (212) C0AF70E8-4588-31BE-B075-ACE0368DDB18 <114 18 7 6 3>
122 2 0xffffff7f95da5000 0xfff1 0xfff1 com.apple.driver.AppleOnboardSerial (1.0) F01EBA9A-E59F-3846-941F-C9986D62E47C <110 53 9 7 6 3 1>
123 1 0xffffff7f95d65000 0x2000 0x2000 com.apple.driver.AppleIntelLpssUARTCommon (3.0.60) E71E15BA-2901-39A6-BCEF-7DE9702E9E9D <122 110 17 16 9 7 6 3 1>
124 0 0xffffff7f95d6c000 0xff4 0xff4 com.apple.driver.AppleIntelLpssUARTv1 (3.0.60) A8913216-3287-3AFE-B4F0-D5AF436BEB97 <123 122 110 17 16 9 7 6 3 1>
125 0 0xffffff7f94f9f000 0x14ff8 0x14ff8 com.apple.driver.AppleCameraInterface (7.13.0) 5236638A-46DF-3911-9417-BA9E89643F5F <98 17 9 8 7 6 3 1>
126 4 0xffffff7f96224000 0x3ffd 0x3ffd com.apple.driver.IOPlatformPluginFamily (6.0.0d8) 9F3308ED-9E10-380B-94A4-46B5EB919259 <16 9 8 7 6 3>
127 0 0xffffff7f95d82000 0x3000 0x3000 com.apple.driver.AppleIntelPCHPMC (2.0.1) A09B9284-7028-3F99-A27A-F32F6F312B3B <126 18 17 16 6 3>
128 1 0xffffff8002fdc000 0x2ff5 0x2ff5 com.apple.iokit.IOSlowAdaptiveClockingFamily (1.0.0) 0C635D85-F0F2-3456-993D-FB812E244109 <9 8 7 6 3 1>
129 0 0xffffff7f95d89000 0xfff 0xfff com.apple.driver.AppleIntelSlowAdaptiveClocking (4.0.0) 3997D94F-122B-37B1-A644-5BBA8B2800A2 <128 6 3>
130 0 0xffffff7f950f9000 0x6ff4 0x6ff4 com.apple.AppleGPUWrangler (7.1.18) 9A58C25C-E480-36D4-B487-8D26F46D4D58 <117 114 17 9 8 7 6 3 1>
131 1 0xffffff7f94f82000 0x2000 0x2000 com.apple.driver.AppleBacklightExpert (1.1.0) 72F88AA3-8C1E-3937-B338-9E1CDA5B136A <120 114 18 17 7 6 3>
132 0 0xffffff7f94f7c000 0x2ff3 0x2ff3 com.apple.driver.AppleBacklight (180.8) E2C23F0B-E8BE-3F11-8AA6-D6195FC3A7CF <131 120 114 17 7 6 3>
134 1 0xffffff7f96291000 0x65ffa 0x65ffa com.apple.plugin.IOgPTPPlugin (1150.2) C199618B-8A00-3D13-9CB4-808F69811137 <59 54 53 51 13 8 7 6 3 1>
136 0 0xffffff8001bb6000 0x21000 0x21000 com.apple.driver.AppleThunderboltDPOutAdapter (8.5.1) 032AE0A3-AFE8-3B91-841E-BD8199DB7D9F <107 82 16 7 6 3 1>
138 0 0xffffff7f95e45000 0x3e000 0x3e000 com.apple.driver.AppleThunderboltIP (4.0.3) FA0DE28D-EFE8-3CDA-A937-9BD0F75DCCF7 <82 51 17 7 6 3 1>
139 0 0xffffff7f95a02000 0xbdff9 0xbdff9 com.apple.driver.AppleIntelKBLGraphics (20.0.6) 35F05F6E-98AE-3CB6-8553-236A44031B2C <118 114 98 17 9 8 7 6 3 1>
140 0 0xffffff7f9504b000 0xcfff 0xcfff com.apple.driver.AppleDiskImages2 (198.100.13) 0025D8BC-B9F2-35F7-9631-929E23F3F252 <36 8 7 6 3 1>
141 0 0xffffff7f9536e000 0x13ff4 0x13ff4 com.apple.driver.AppleHV (1) C56759DB-6AED-3168-B9C4-D6070713EEBB <44 9 8 7 6 3 1>
142 0 0xffffff7f95386000 0x5000 0x5000 com.apple.driver.AppleIPAppender (1.0) 1C1B716E-235C-3A5A-B507-D827E1FF4E86 <53 51 9 8 7 6 3 1>
143 1 0xffffff7f9626e000 0x4000 0x4000 com.apple.iokit.IORSMFamily (1) 4BDFBD71-CFA0-374F-A399-4738645D191C <7 6 3 1>
144 0 0xffffff7f95de3000 0x4ffc 0x4ffc com.apple.driver.AppleRSMChannel (1) 483D379C-609D-3271-A80E-D18DB74C5EF0 <143 8 7 6 3 1>
145 0 0xffffff7f95f44000 0xfff 0xfff com.apple.iokit.BroadcomBluetooth20703USBTransport (9.0.0) 7B70575D-1DA2-3667-851F-B12CCE183E0C <9 8 7 6 3>
146 0 0xffffff7f95f47000 0x1000 0x1000 com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport (9.0.0) A80AE7AC-7FDB-3968-BC23-F13F20FE9EC4 <9 8 7 6 3>
147 0 0xffffff7f95f4a000 0xfff 0xfff com.apple.iokit.CSRBluetoothHostControllerUSBTransport (9.0.0) 23D674AC-7739-32F5-B64D-3C1104EA4DE8 <9 8 7 6 3>
148 0 0xffffff7f95fab000 0x13ff8 0x13ff8 com.apple.iokit.IOAVBFamily (1140.6) 80E06CBA-CEBF-3E99-9FC9-65648E6E98E1 <134 54 51 8 7 6 3 1>
149 0 0xffffff7f960ce000 0xfff 0xfff com.apple.driver.IOBluetoothHostControllerPCIeTransport (9.0.0) 4416A03B-7349-31B1-9E35-E2CA2644C673 <9 8 7 6 3>
150 0 0xffffff7f960d1000 0xfff 0xfff com.apple.iokit.IOBluetoothHostControllerTransport (9.0.0) 6992EFEA-B257-3462-9185-C3D870DD7B85 <9 8 7 6 3>
151 0 0xffffff7f960d4000 0xfff 0xfff com.apple.iokit.IOBluetoothHostControllerUARTTransport (9.0.0) 3B804DF9-6F64-3895-81F1-D5312EB9155F <9 8 7 6 3>
152 1 0xffffff7f96251000 0x12ffa 0x12ffa com.apple.driver.X86PlatformPlugin (1.0.0) C812E4A1-E413-367F-9805-ABC6A14167AC <126 25 18 16 9 8 7 6 3 1>
155 0 0xffffff7f960d7000 0x1000 0x1000 com.apple.iokit.IOBluetoothHostControllerUSBTransport (9.0.0) 605B865E-EE05-31D5-9458-28B8BC19FD0C <9 8 7 6 3>
156 0 0xffffff7f960da000 0x1000 0x1000 com.apple.iokit.IOBluetoothPacketLogger (9.0.0) 9D6725C5-4683-305C-AA29-D963B6DE6C13 <9 8 7 6 3>
157 0 0xffffff7f960dd000 0xfff 0xfff com.apple.iokit.IOBluetoothSerialManager (9.0.0) D1A02830-07A6-3FCB-A615-82E15509D37A <9 8 7 6 3>
158 1 0xffffff7f94f96000 0x4ff2 0x4ff2 com.apple.driver.AppleCallbackPowerSource (1) 45D69C11-98A9-30DE-B5CD-F18E72614D9A <8 7 6 3 1>
159 0 0xffffff7f9620a000 0x6ff7 0x6ff7 com.apple.driver.IOHIDPowerSource (1) 7AB1876B-E26C-3976-A850-D24DAF1D40C5 <158 59 8 7 6 3 1>
160 0 0xffffff7f96330000 0x14ff4 0x14ff4 com.apple.driver.usb.AppleUSBUserHCI (1) B4C8AFF3-DCD2-35AB-8B8B-0172799E4F8D <25 23 7 6 3 1>
161 0 0xffffff7f96352000 0x3fff 0x3fff com.apple.iokit.IOUserEthernet (1.0.1) 80AC1850-F0D1-33EB-8405-1F7D78EC6E6E <51 8 7 6 3 1>
162 3 0xffffff7f966ff000 0x2ffd 0x2ffd com.apple.kext.triggers (1.0) BD756F9A-43AF-3B6A-86F1-97A802970316 <9 8 7 6 3 1>
163 0 0xffffff7f965b5000 0x9aff4 0x9aff4 com.apple.filesystems.nfs (1) A6039CCF-CBE8-3398-8482-DA46AE7F7702 <162 10 9 8 7 6 3 1>
164 0 0xffffff7f96656000 0x9000 0x9000 com.apple.driver.pmtelemetry (1) 5DACFD6A-6BF9-3A79-B2F3-ECABB72629FE <9 8 7 6 3 1>
167 0 0xffffff7f96584000 0x1000 0x1000 com.apple.driver.eficheck (1) 60F3C418-FD72-3A1E-816A-990EBF861212 <64 17 6 3 1>
168 0 0xffffff7f950f5000 0x1ffe 0x1ffe com.apple.AGDCPluginDisplayMetrics (7.1.18) 2388CD32-143C-319A-8F8F-173FB6AF5D84 <117 9 8 7 6 3 1>
169 2 0xffffff7f9673b000 0xc1fec 0xc1fec com.apple.vecLib.kext (1.2.0) AE5EFF10-F32C-3F4D-90D2-5C762C4E0519 <13 9 8 7 6 3>
170 4 0xffffff7f960a6000 0x1dff0 0x1dff0 com.apple.iokit.IOAudioFamily (440.2) 626EA2F4-ED14-3987-AEEE-C183C95B4731 <169 7 6 3 1>
172 2 0xffffff7f95365000 0x3ffc 0x3ffc com.apple.iokit.IOHDAFamily (440.2) 900235B5-1D57-31BE-B43A-B2562B64C9FB <7 6 3 1>
173 1 0xffffff7f95241000 0x12ff4 0x12ff4 com.apple.driver.AppleHDAController (440.2) E92DDE1B-681C-33D3-9FA7-610AE5EB249B <172 170 114 17 9 8 7 6 3 1>
174 1 0xffffff7f950ec000 0xfff 0xfff com.apple.driver.AppleGraphicsControl (7.1.18) 43869897-FA64-3461-B5EE-9594DA6B29CA <9 7 6 3 1>
175 0 0xffffff7f9510d000 0xc000 0xc000 com.apple.driver.AppleGraphicsDevicePolicy (7.1.18) 7EAAD433-C39A-337A-B99F-86C0619CE497 <174 117 114 17 16 9 8 7 6 3 1>
176 0 0xffffff7f95f13000 0x3000 0x3000 com.apple.driver.AppleUpstreamUserClient (3.6.9) 9C1B870C-F5F0-370D-8630-9B89E6C03A11 <114 17 16 9 7 6 3 1>
177 1 0xffffff7f96374000 0xf000 0xf000 com.apple.kext.OSvKernDSPLib (530) 35810D8D-EDB2-331A-8E17-59879627A177 <8 7 6 3>
178 1 0xffffff7f95271000 0xe2ff8 0xe2ff8 com.apple.driver.DspFuncLib (440.2) A199D19B-2689-3DFF-B461-A5956BC976ED <177 170 169 67 8 7 6 3 1>
179 0 0xffffff7f9518a000 0x8fff0 0x8fff0 com.apple.driver.AppleHDA (440.2) D8129302-91D6-382A-9EEA-21DAE11270F1 <178 173 172 170 120 114 8 7 6 3 1>
181 0 0xffffff7f9656b000 0x8000 0x8000 com.apple.filesystems.autofs (3.0) 6631673F-0234-3275-BA34-5F3104B29D6B <162 9 8 7 6 3 2 1>
182 0 0xffffff7f95dde000 0x1fff 0x1fff com.apple.driver.ApplePlatformEnabler (2.7.0d0) 221D07C8-329A-3C68-9135-7F79FD1C3155 <9 7 6 3>
183 0 0xffffff7f95166000 0x1eff8 0x1eff8 com.apple.driver.AGPM (131) FD00A16C-CC54-3CA4-A8ED-48BD0E609F59 <126 120 117 114 17 8 7 6 3 1>
184 1 0xffffff7f96266000 0x6000 0x6000 com.apple.driver.X86PlatformShim (1.0.0) F95AA991-F15C-371A-8966-E764C030D925 <152 126 18 9 6 3>
185 0 0xffffff7f95f22000 0x3000 0x3000 com.apple.driver.AudioAUUC (1.70) 1F0EAF2B-E5B4-3FE2-941B-E00EDA061DC8 <170 114 17 16 9 7 6 3 1>
187 0 0xffffff7f96673000 0x81ff1 0x81ff1 com.apple.filesystems.smbfs (5.0) BE4A1C90-80D4-36E2-A5F7-37575D2024E3 <162 10 9 8 7 6 3 1>
Please keep in mind I got this computer used on Ebay and not even sure what all of these kext are for. I am tempted to wipe clean this computer and start fresh. I was told it was freshened to a clean state.
If you have nothing precious on the drive then might be good to do this irrespective of the laser connectivity, especially if you bought the system used.
If you do so, I’d suggest attempting to connect the laser without first installing any 3rd party drivers.
Is there any harm deleting all kext files in the folder /System/Library/Extensions?
Additionally I searched in these files and found many “com.apple.driver.usb” files.
This is very infuriating. I decided to erase my mac. I followed the instructions on this page using the Intel chip instructions. What to do before you sell, give away, trade in, or recycle your Mac - Apple Support
I also reset the NVRAM as suggested. After all that was done I setup my computer again logging into my cloud account. I first queried system report and was able to see the tool in my USB section. I downloaded Xtool Creative Space and tried to connect. The tool could not find my USB connection. The instructions they provide is to follow this support page and install drivers https://support.xtool.com/hc/en-us/articles/7934477424407-Target-device-not-found-when-connecting?_gl=1*1386l7r*_ga*MTI4ODM5OTgyMS4xNjk2NzE1NTg0*_ga_W46SBPZ1NW*MTY5NjcxNTU4NC4xLjAuMTY5NjcxNTU4NS4wLjAuMA…
I skipped this just to see if Lightburn would find my tool. I downloaded the config file they provide from support page (link in next post)
I installed config file and tried to connect with no luck.
Links can be provided. I tried but it marked my post as spam so reposting without links
This would make your Mac unusable. There are many drivers required for the normal functioning of the system.
What does System Report show now?
If XCS cannot connect it’s likely that Lighburn will also fail.
It shows the connection. I oped to try the driver again.
Can you list all the currently relevant WCH drivers? You likely have 2 sets if you’ve installed the 3rd party driver and the System Report showed the connection previously without the driver installed.
How would I query this to show?
